clunky sound
Old Oct 26, 2009 | 04:30 PM
maxs4life's Avatar
clunky sound
im having a clunking sound and im not sure what it can be...
I just changed my struts and outer tie rods... boths sides
on the stablizer links are they suppose to be any play??
what could it be??
control arm bushing??
Link Ends
Inner tie rod
The sound happens when only when i dip into a pot hole or a bump
Old Oct 26, 2009 | 08:28 PM
Andy2000max's Avatar
Most likely is your sway bar end links. They are about $20 each from Advance (Moog). Easy to get to...often not easy to get loose. My recommendation would be to soak them with PB Blaster for a day before trying to break the bolts loose.
Old Oct 26, 2009 | 08:33 PM
Nelsito65's Avatar
on the end links.
Changing those is what rid my car of the clunking noise
Old Oct 26, 2009 | 08:50 PM
Feldman's Avatar
I agree with the end link diagnosis but since you just did some work in the area it could be any number of things.
Old Oct 26, 2009 | 09:37 PM
anomaly117's Avatar
just had my ball joints replaced, still got a clunking sound. guess what it is??
driver's side sway bar end link ESPECIALLY if you only hear it in bumps. trust me.
Old Oct 27, 2009 | 01:16 AM
Jeff03sixer's Avatar
my sound was motor mounts. hit a bump and sound like a loose suspension component. changed struts, endlinks, swaybar bushings but still had the noise (car did drive much better tho). changed the front and rear motor mounts.... voila. front one was bad, cracked and liquid dripping out.
Old Oct 27, 2009 | 05:03 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
mine does the same... going to the mech on friday.. motor mount bad (front)
Old Oct 27, 2009 | 07:34 AM
maxs4life's Avatar
funny u guys have bad engine mounts because mines is broken too. its probably links or engine mount. Does ES sell mounts for a 3.5 Max??
Old Oct 27, 2009 | 08:02 AM
maxs4life's Avatar
i checked the sway bar links and theres just a little play.. nothing major. i have a bad front motor mount could that be the problem.
Old Oct 27, 2009 | 08:08 AM
Rochester's Avatar
Absolutely. Solid polyurethane mount inserts for the manual transmission. Don't know about the automatic... I believe there's a difference. Search for a while and you'll figure it all out.
The ES mount inserts are fantastic. The car is totally planted now on the launch. Say goodbye to wheel-hop.
Old Oct 27, 2009 | 09:16 AM
maxs4life's Avatar
manuel ones are easy to find.. Cant find the AT ones
Old Oct 27, 2009 | 10:56 AM
bigpimpen092's Avatar
My clunky sound turned out to be both my ball joints. A mechanic who did my whole change said there both about to fall out. The car always makes that noise even after you fix it so I just run it until it breaks.
Old Jul 4, 2010 | 01:10 AM
richardcd's Avatar
What could cause this very loud intermittent dull clunking sound from my rear suspension that has occurred from new in April 2002? Since it is intermittent and does not occur most of the time, I never bothered to have it checked under warranty. Since then, I had it checked by a dealer who found no problem. When it occurs, it happens when going over bumps such as railroad tracks and speed bumps.
Old Jul 22, 2010 | 09:13 PM
DIYallthetime's Avatar
Sounds like possibly blown struts, or a wheel bearing could be shot? Rear suspension should be fairly easy to diagnose at a reliable shop with a lift
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
