want to see ES Bushing installed
Old Oct 27, 2009 | 01:36 PM
maxs4life's Avatar
Im going to change some bushing on my car this week or next week and i want to double check that the things im purchasing are correct.
If anyone can direct me or show me these bushing on there car
Control arm bushing
motor mount bushing
sub frame bushings..
I have a 3.5 Maxima se
Old Oct 27, 2009 | 02:57 PM
vastmax's Avatar
are you attempting this yourself? You will need a press...
I have a press and still cant get the smallest control arm bushing out.
Old Oct 27, 2009 | 03:02 PM
knight_yyz's Avatar
Toolie
you have to cut the bushings out of the control arms. Its melted onto the pin... You need a die grinder with a zip cut wheel, being very careful not to cut the pin. And watch out for the liquid inside the bushing. Very messy when the zip cut starts slicing through
Old Oct 27, 2009 | 04:11 PM
Gemner's Avatar
one of the bushings you press out and the other you release the press fit by making a large dent with a chisel or something else, then it easily comes off (unless rusted on)
Old Oct 27, 2009 | 04:24 PM
maxs4life's Avatar
nah im not doing the job myself
dont have time or space or patience
Old Nov 8, 2009 | 05:06 PM
Ghost_54's Avatar
Front engine mount ES bushing with a custom sleeve pressed in as mine is an automatic & the top smaller ES bushing:
this pick shows the under neath sub ES bushing also replaced:
Front engine mount ES bushing:
Full pic of the replacement of the crossmember with all the ES bushing replaced:
All work prep'd and installed by knight_yyz
Old Nov 8, 2009 | 05:46 PM
Gemner's Avatar
Originally Posted by Ghost_54
Rear engine mount ES bushing:
I bet thats the front
Old Nov 8, 2009 | 06:00 PM
Ghost_54's Avatar
^^ edited my original post
well as someone pointed out it is actually a side as the engine in mounted sideways, the mount with the aluminum insert pressed in is the front as it is the larger of the two because I have an automatic with the electronic mount which they don't make a bushing that size ... so knight_yyz made an insert to spec and then pressed it in ... in any event the originally poster was after a few pic's of the all the ES bushing inserts for the engine mounts and as I had all mine done he can get a least get a visual on the install
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
2kmaximel
Sep 16, 2015 03:19 PM
Bonka
Sep 14, 2015 11:18 PM
