02 parts on 01 Max
02 parts on 01 Max
Ok so my buddy has a wrecked 02 Maxima and said whatever parts I could get off of it and would fit on my 01 Max, I could have. The interior of the 02 is leather and both front seats are power and heated.
My interior is cloth and only my driver side seat is power, neither are heated. I don't really care for the heated part but do you think the harness for power seats is somewhere in the car just with a manual seat or is that a big No?
Also the wheels on it are the 7 spokes
Will they fit on my 01?
Then the taillights are this type:
What would I need to make them fit?
All those parts should be interchangeable without any modifications. The 00-03 tails are the same size, just different designs. The rims have a slightly different offset on the 02 than on the 01, but they will fit.
As for the power seats, I'm not totally sure. The plugs shouldn't be different from the 01 to the 02, but I could be wrong. When the blower motor for my heater went bad in my '02, I replaced it with a motor from an '01. The only difference between the two units was that the plug was in a slightly different location. Not far enough off to affect re-installation, though.
Oh, also, I don't know if the seat mounts are the same in '01 and '02. I don't see any reason why Nissan would change it, though.
Taillights-yes, get his harness from it too
Wheels-yes
There are no plugs IIRC to just plug in the power seats, you can grab them though and just take them apart and fit them onto your seat frame pieces, Write-up is around here on the org
Other things I would grap
Headlights, Sideskirts, engine, tranny, and his brakes
Wheels-yes
I believe your car should have the wiring harness for the heated seats preinstalled. You simply have to trace it through the panels. If you are getting the heated seats, make sure you grab the harness from the wrecked car as well so you could retrofit everything correctly. Just because your Maxima has pre-existing harness, doesn't mean the plugs are identical between the 01 and 02. The easiest way to check whether your vehicle has the heater harness is by checking the fuse box.
The wheels and taillights are dirct bolt-on, but I believe the ones already on your car is more desirable. I may be wrong though.
My tails are the red ones and I would prefer the clear ones and my wheels are base models so I definitely prefer the 7 spokes. Will just inspect to see if I have the harness for the power seats already there. As said above I don't really care for the heated part.
I don't believe the cloth seats have side airbags. It usually says srs airbaigs on the side where the seat belt is at or at the head rest
P.S I may be interested in the fog lights if the price is right lol
. I will trade you my SE rims for those GLE rims as I think those were the best looking Max rims besides the sport rims on the 09's......hehe!
dank4us
34
Jun 10, 2024 03:45 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
FlaMark
25
Aug 28, 2015 10:15 AM
kirkhilles
Aug 8, 2015 10:53 AM
