maf
Old Nov 15, 2009 | 10:46 PM
jjj's Avatar
jjj
maf
maf, o2 sensor, and gear 1 and 2 ratio
I have the following codes and my car is hesitating bad when engine rpm goes over 2000. drives like there is a governor on engine above 2000rpm.
any help would be appreciated:
P0102 (twice) MAF OR VAF CIRCUIT LOW INPUT
P0159 O2 SENSOR CHECK SLOW RESPONCE
P1167
P0732 GEAR 2 RATIO
P0731 GEAR 1 RATIO
Old Nov 16, 2009 | 06:47 AM
rroderiques77's Avatar
Demodded and Forgotten
Replace MAF and clear codes. The O2 codes may not return. I am not entirely sure as far as the tranny codes.
Old Nov 16, 2009 | 09:16 AM
jjj's Avatar
jjj
any other suggestions
any other input would be appreciated.
i removed and cleaned maf. it looked normal, clean and un-damaged.
seems like waist of $$ if its shows sensor related and i replace expensive maf and it doesnt resolve problem and i cant return part.
Old Nov 16, 2009 | 09:55 AM
Did it help the MAF? Is it running better now?
Old Nov 16, 2009 | 03:06 PM
soxruled0's Avatar
I had the exact same problem, my car was giving the same codes. I replaced the MAF and it fixed it. I'm not sure if that helps you.
Old Nov 21, 2009 | 11:11 AM
wetnoodle's Avatar
there is a sensor in there. you could have cleaned the MAF to look brand new...but if the sensor is toast, no amount of cleaning will bring it back. I've spotted MAF's for these under $160. I know it sucks, but the general consensus is to replace it. Good luck!
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
