Brake problems
Old Nov 17, 2009 | 05:40 PM
Grand_hustle17's Avatar
Brake problems
So i see its that time of year that my max chooses to fail on me... multiple problems happening every other day... first my exhaust starts hanging, startup problem (gotta tap the gas pedal on startup), fog light wire actually breaks in two (IDK how the hell that happens)... my main problem is my breaks, so i went to chill with a couple of fellow orgers at the track, and on my way out we decided to hit up Mcdonalds, soon as im pulling in i hit the breaks (pads and rotors are already bad) all the sudden a quick snap and the break pedal went slam to the floor, had to pass the turn and use the E-break... managed to roll home, after installing my powerstop rotors and pads i noticed the lines had a small leak but that wasnt the problem, it only leaked once but i've been driving like that for two days now and i still have break fluid, spoke to kingjames and he was saying possibly the master cyl... anybody care to chime in??? i have to press the pedal about all the way down to even slow down...
Old Nov 17, 2009 | 05:43 PM
a33i30's Avatar
Brake*
Old Nov 17, 2009 | 06:13 PM
jasonmax's Avatar
air gets in the line probably?
replace everything thats broken?
youve posted 8k posts here and youre asking us for opinions?
Old Nov 17, 2009 | 06:26 PM
mandyfig's Avatar
Wow, 8K posts....the guy is asking for opinions....let's give it. Will be the master I suspect!
Old Nov 17, 2009 | 06:34 PM
The6spdMax's Avatar
Either air got into the brake line or bad master cylinder. Have you bleed your brake fluid yet?
Old Nov 17, 2009 | 09:34 PM
rroderiques77's Avatar
Demodded and Forgotten
You have a cracked hose? A good place to start would be to replace it and bleed. Your master is probably ok.
What do you mean by, "pads and rotors are bad?" Are you grinding m/m? Did you blow out your caliper? Need more info Hustler.
Old Nov 18, 2009 | 03:51 AM
phatboislim's Avatar
1st i'd say bleed your whole system (RR, LF, RL, RF)
2nd i'd say check/replace that line
3rd i'd say to replace teh master cylinder
Old Nov 18, 2009 | 03:59 AM
SteveB123's Avatar
Fail.
Old Nov 18, 2009 | 12:16 PM
lol.. my previous rotors and pads was bad... pads worn down grinding on the rotor and slightly grooved it... ill probebly replace the lines... get some stainless steel ones...
Old Nov 18, 2009 | 12:18 PM
do you think it takes 8000 post on a forum to know every possible problems to a car???
Old Nov 18, 2009 | 12:46 PM
SteveB123's Avatar
Quite obviously, post count means nothing in terms of knowledge.
Here's a little tid-bit for you to chew on:
If brake fluid has leaked out, air has leaked in.
You're driving around in a time bomb, for which YOU are libel for.
Old Nov 18, 2009 | 02:04 PM
vball_max's Avatar
....except switch 1 and 2. If you bleed them first, you will need to bleed them again when you replace that line.
Old Nov 18, 2009 | 02:26 PM
jasonmax's Avatar
seems like youve found the problem.
Old Nov 18, 2009 | 03:37 PM
or leave it as is and just add 2 to 1? lol...just trying to save a few bucks...lol
Old Nov 18, 2009 | 04:27 PM
some of yall ****'s be having the smartest comments like this aint a mothfcukin forum... i swear maxima.org is probebly the worst forum that exists right now, just like all else who changed from a maxima or just leave the community because its so ******* dumb... my post count will change from 8K to 12K in a week cause im just gonna go around ******* this forum up more than it already is... **** out of my thread
Old Nov 18, 2009 | 04:34 PM
MoncefA33's Avatar
Yo dude relax.
If you're just realizing this then obviously there's a problem here. Maxima.org is full of cheap bastards and smartasses.
But there are people with more than enough knowledge. Anyways, get SS brake lines, install accordingly and fill with brake fluid.
EDIT: Maxima.org isn't a bad forum. Look at the people who actually make contributions. They do a lot for the board and for a car that doesn't have a Honda Civic-like amount of parts available for it. Yet there's a lot of innovation here for cars that may be looked upon only as grocery getters by other people. And compared to even the 350Z boards I think there's a higher proportion of innovative minds here than there.
Old Nov 18, 2009 | 04:42 PM
^^^^^^^^^^^^^this
Relax Hustler. Don't let the dweebs bring you down.
There are some of us here that are quality people.
Old Nov 18, 2009 | 04:57 PM
MoncefA33's Avatar
Like me. I'm pretty damn awesome
Old Nov 18, 2009 | 05:01 PM
its one of those post that was waiting to happen for about a year now... it just keeps getting worse and worse... im not mad, just more irritated with the forums everytime i log in... sometimes i dont even know why i bother post anything
Old Nov 18, 2009 | 05:34 PM
a33i30's Avatar
It's my fault:/
Old Nov 18, 2009 | 06:56 PM
CMax03's Avatar
Fix your BRAKE hoses, b4 it BREAKS in two!!!!!
Old Nov 20, 2009 | 07:56 AM
josh662234's Avatar
some ppl are so obnoxious. if you dont have an opinion to help hustle, then dont make a wise A$$ comment to increase your post count
Old Nov 24, 2009 | 06:08 PM
cbrown_17's Avatar
****in Breaks and rotors!!
recently replaced my rotors and breaks!,all round! after a few days of driving the ABS LIGHT TCS AND SLIP LIGHTS ARE coming on and staying on . does anyone have any recommendations before i go and spend 300 plus to have Midas check them.
Old Nov 24, 2009 | 09:48 PM
Why would Midas charge "300 plus" to check them?
Old Nov 25, 2009 | 11:12 AM
Jmahad01's Avatar
I dont know about the $300 but I believe only the snap on scanners or the consult II can check those lights.Maybe some other higher end scanners.
Old Nov 25, 2009 | 05:40 PM
cbrown_17's Avatar
Thats a ball park figure
Old Nov 25, 2009 | 06:00 PM
allmotor2010's Avatar
x2 bleed the break lines!
Old Nov 25, 2009 | 06:53 PM
boost4age's Avatar
Midas is pretty expensive when it comes to having work done by them. They wanted to charge me $286 for re surfacing the rotors, flush of break fluid and caliper silde service.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
