5th Gen Tech Question
Old Nov 26, 2009 | 01:08 AM
VQtHuRtY's Avatar
I've been looking to do a 3.5 swap done to my 5.0 Gen Maxima as well as the AT to MT swap altogether. So I decided my best bet is to get a wrecked Maxi with the 3.5 MT. My question is will a 3.5 engine from a Altima SE-R, 6thGen Maxima fit the 5th gen? Are they all the same or do they vary. Any help will be thanked...
Old Nov 27, 2009 | 12:24 AM
VQtHuRtY's Avatar
Bump! Anyone knows?
Old Nov 27, 2009 | 01:37 AM
knight_yyz's Avatar
Toolie
it will fit, but you will need more than that for the swap, new axles for one thing. Might need an ECU because the newer generation motor has a few more bells and whistles on it.
Old Nov 27, 2009 | 01:41 PM
MoncefA33's Avatar
You won't need an ECU if you do a 3.5 swap with the 3.0 timing equipment, you can just run the 3.0 ECU. You'll also need the cam spacers for the 3.5 cams to work with the 3.0 timing equipment.
Old Nov 30, 2009 | 01:00 AM
VQtHuRtY's Avatar
Well, Im planning on buying a wrecked maxi so anything I need I would pull it off the wrecked maxi. My question is does it have to be a 5.5 Gen Maxi or could it be the Altima Se-R 3.5 engine, or the 6th gen Maxima's 3.5? Are they all the same thing?
Old Nov 30, 2009 | 05:31 AM
MoncefA33's Avatar
Yeah, same thing.
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ef9
Aug 27, 2015 07:21 AM
