Air conditioning problem
Old Nov 30, 2009 | 05:56 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Ok another thread, Damn it anothr issue. Here it is... I can hear the A/C turning on and the compressor going on, but no air comming into the cabin. It just stop, everything is fine, check the fuse inside the cabin and it is fine. What can it be before taking it to the mechanic and he :butsheek: me, again. Thanks
Old Nov 30, 2009 | 06:13 PM
VQP0WER's Avatar
Your blend door might not be closing, but to verify the compressor and everything is alright, a pressure check with manifold gauges needs to be hooked up.
Old Nov 30, 2009 | 09:42 PM
KJVA67's Avatar
STUCK IN ATL
From: JACKSONVILLE, FL. STUCK IN ATL FOR THE TIME BEING
Do you have auto AC control
On my last max, (95) I had that issue. The climate control would show AC on, fan on high, and no air was moving. Can you feel cold air, seeping out of the vents when you drive? If so, the ac is working, its just the control isn't turning the fan on. You may need a new climate control unit.
Old Nov 30, 2009 | 10:37 PM
jasonmax's Avatar
blowermotor not working?
Old Dec 1, 2009 | 04:15 AM
Lontar1's Avatar
it came on again this morning, but died again.... where is the blower motor located? The climate control is working fine, the blower is not moving the air inside the cabin
Old Dec 1, 2009 | 05:18 AM
bryan163's Avatar
Disconnect the blower motor and see if there is power at the harness. If you have power there you can blame the motor, if not it could be the controller.
If you don't already have a service manual, you should pick one up. They have all the wiring diagrams in the back. A multimeter, set to "DC volts" should be used to check for power.
Old Dec 1, 2009 | 05:29 AM
Prophecy99's Avatar
sounds like symptoms I had of a bad blower motor.
Old Dec 1, 2009 | 06:40 AM
Lontar1's Avatar
I will do that tonight.... thanks, I know I need a service manual.... too lazy lately.
Old Dec 1, 2009 | 08:17 AM
jasonmax's Avatar
check the fuses under the hood first, change them. if they blew at low and mid settings, you have a bad blower motor. change the motor before it ruins the amplifier.
Old Dec 1, 2009 | 08:36 AM
Lontar1's Avatar
I think the motor is bad, as it was making some noises a while back, do you know how much does this run for?
Old Dec 1, 2009 | 08:51 AM
williamgd2's Avatar
Check the blower motor switch or fan control ,They can overheat and die.I have put 2 in Luckily I found the whole control head on ebay for like $5.00
Old Dec 1, 2009 | 12:02 PM
jasonmax's Avatar
depends, I think its like 200 bucks
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
egali045
Aug 5, 2015 09:02 AM
