Middle of doing belts.... Need Help
Old Dec 12, 2009 | 09:02 AM
kukx30de's Avatar
So I finally got down to doing the belts this morning.
Thankfully all 3 bolts on the PS pump are now loose.
However, I cant get the belt off the P/S pump.
What am I doing wrong??
The back bolt is loose and I can move it with hand.
The long tensioner adjustment bolt is super loose so is the lock nut.
Any pointers?
Old Dec 12, 2009 | 09:40 AM
rroderiques77's Avatar
Demodded and Forgotten
Don't you have to pull the A/C belt off 1st?
Old Dec 12, 2009 | 09:49 AM
kukx30de's Avatar
AC belt is already off.
Infact in the last few minutes I loosened the tensioner adjuster bolt so much that that the bolt and the long bolt are now off the car!
I hv no clue what is going on.
Even with the tensioner bolt off the car the ps belt wont come off... its more loose than it was when i started, but not enough to get it off.
Old Dec 12, 2009 | 09:53 AM
Is the belt loose. Put a pry bar on that *****.
Old Dec 12, 2009 | 10:02 AM
kukx30de's Avatar
I guess i can do that...
I was reading on releasing the long bolt the ps pump should lower or something like that.
I already have the back bolt loose and now the assembly that locks the long bolt is off.
Even with that the belt cant be taken off.
I need to atleast get the long bolt back on the car...
What am i doing wrong here
Old Dec 12, 2009 | 10:43 AM
kukx30de's Avatar
Finally freaking belt is OFF!!!
I have to say.... none of the bolts are hard....
Its that bolt that faces the bottom that is the total F**K.
I need to take some pics and put them up....!
Thanks RR!
DJLAX152
May 4, 2021 11:46 AM
Melissa40
Jun 30, 2017 10:04 AM
gigabyte
Jan 6, 2017 06:05 PM
RWCreative
Sep 21, 2015 11:01 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
