lower clutch hose leaking
Old Jan 18, 2010 | 06:49 AM
dozu's Avatar
'01 SE.... has been leaking fluid slowly (at the rate of 1 resevoir per week)... it appears that the lower clutch hose is leaking (looks quite wet).
questions -
1) should I replace only the hose, or also the slave cylinder? (original slave, car has 160k miles).
2) is such a job suitable for the DIYer? ( have done light DIY stuff myself.... oils, fluids, brakes, bulbs etc.. nothing heavy duty).. is there any write-up for the hose/slave replacement? I searched around and coulnd't find any.... local garage quoted me $270 labor for the hose+slave, which ain't terrible.
thanks all.
Old Jan 18, 2010 | 07:05 AM
Derrick2k2SE's Avatar
Yes, you can do it. It's easier than brakes.
No, don't replace the slave if it's working.
Just remove the hose and have something to catch the fluid. Install the new hose and bleed the line.
Old Jan 18, 2010 | 08:52 AM
redrelyt12's Avatar
very easy job, did it yesterday myself
Old Apr 17, 2010 | 04:28 PM
dozu's Avatar
damn them bolts
so I removed the air duct to reach the bolts. none of them budged at all.
especially the one on the higher side - when I tried to force it, it felt as if I am bending the flange, but the bolts didnt loosen at all.
any tricks?
should I throw in the towl and let the greese monkeys handle it?
thanks much!
Old Apr 21, 2010 | 11:46 AM
dozu's Avatar
I did it! but...
How do I bleed the line?
thanks much!
Old Apr 21, 2010 | 02:30 PM
Amave's Avatar
thanks much!
same as brakes....
have someone pump the clutch pedal, then crack open the bleeder to remove air ...
Old Apr 21, 2010 | 04:11 PM
dozu's Avatar
Originally Posted by Amave
same as brakes....
thanks for all the help guys.... i did the bleeding and it works as new now
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Starrider
Dec 18, 2015 04:43 AM
ag90fox
Sep 9, 2015 12:22 PM
dcam0326
Sep 7, 2015 07:26 AM
