WHAT size rims fit best the 2003 maxima se
Old Jan 21, 2010 | 03:52 PM
tothemax2003's Avatar
i have been wanting to put 5 star chrome rims on my car and wanted to get expert advice on what size rim would fit the best without hurting the ride of the car.My car came original with 17 inch , i am sure you guys already know that.
Old Jan 21, 2010 | 05:32 PM
Scottwax's Avatar
That's Mr. Detail to you
Stick with 17 or 18" wheels if you don't want to hurt ride quality.
Old Jan 21, 2010 | 06:27 PM
erty67's Avatar
Decal Specialist
19s.....all day long! 18s aren't bad. no 20s, no 17s or less
Old Jan 21, 2010 | 06:30 PM
HotshotVQ35's Avatar
17 inch lightweight rims = win. anything bigger = fail
Old Jan 21, 2010 | 06:37 PM
erty67's Avatar
Decal Specialist
sorry, I'm all about looks
Old Jan 21, 2010 | 06:55 PM
and im about performance, see you in my rearview mirror
edit..i had 18s for a while, they weighed 55 lbs a side, my
lightweight 17s weigh 43lbs. huge diff in performance...
just my opinion of course
Old Jan 21, 2010 | 07:58 PM
diverdown3's Avatar
If ride quality is to be retained, stick with 17's. You can go an inch wider than stock, but that's it.
My summer wheels are 19's and the ride is rough. My winter wheels are the stock 17's with stock size tires. Much nicer.
Old Jan 21, 2010 | 08:05 PM
Scottwax's Avatar
I like having a stock appearing and sounding car, makes it all that more surprising to others.
Old Jan 21, 2010 | 11:41 PM
Mr. Blue Sky's Avatar
18 inch rims do well in the 5th/5.5 gens, as has been stated above. Offset on the other hand is going to be based on how wide your rims are. If you go with an 8.5 inch wide wheel, you will have to figure out which offset will suit your tastes best.
Old Jan 22, 2010 | 04:30 AM
jamyers's Avatar
22's all summer long.
Old Jan 22, 2010 | 06:47 AM
vball_max's Avatar
Just my opinion, and the ride must suck.
Old Jan 22, 2010 | 07:07 AM
Puppetmaster's Avatar
That's totally up to you... look here:
http://forums.maxima.org/5th-generat...cs-thread.html
http://forums.maxima.org/members-rides-65/
For an idea of what you like on a Maxima.
Old Jan 22, 2010 | 07:23 AM
nismomaxct's Avatar
My 18x8.5's weigh 43 pounds. I had set of Murano rims that I used for about a week after a blowout and hated them. As long as you can get a lightweight wheel in 17 or 18 you will be golden.
Old Jan 22, 2010 | 08:07 AM
e-subliminal-2's Avatar
got 18's here but i'd love to get soem 19" deap dish...
Old Jan 24, 2010 | 10:52 PM
a33_ridah's Avatar
i had 20's/ scraped in the rear all the time with my tokico white/vogtland drop
now i have g35 19" rays. lightweight forged rims
a little rub here and there with full load, but nice fitment, and decent ride.
im even considering dropping to 18's tho in the future.
Old Jan 25, 2010 | 07:10 AM
rvamaxima's Avatar
I'm on 18x8 42 offset 225/45 with S-Techs and Illuminas, no isues.
Old Jan 25, 2010 | 07:45 AM
NissanMan97's Avatar
stick with 18 or 19.
im gonna re-finish my stock 17's. i love the look of the wheel and it will save me money for go-go parts
B
Old Jan 25, 2010 | 08:07 AM
Shift_Max's Avatar
so bigger diameter wheels that are still light and forged are a fail?
my 19s weigh only 19 pounds. Is that a fail?
17 inch looks way to small for the size of a 5th gen IMO.
18s are perfect but 19s fit like a glove.
However like it was stated offset is the key to a perfect set-up.
BTW i am on Tein SS with 245/35/19 and the car rides firm but not bone-jarring. It is not true that bigger wheels = worse ride. The suspension set-up has alot to do with it.
Remember suspension travel is key...
Old Jan 25, 2010 | 08:13 AM
hot_wax_tree's Avatar
ok honestly man the smaller the wheel the more tire you have the side wall and more open space for air in the tire basically make a bigger and bigger coushin as the size of the wheel goes down.
So use your logic and dont listen to the guys saying 19's are fine, cause thos tire are low profile tires. they obviously will have a firm ride. with 18's you will feel a differance in the ride, but personally its really not as dramatic as some people make it out to be. yes its a little stiffer but in the least sense of the word.
I love the look of the stock wheels on a dropped maxima but that just my opinion. and yes to add to your performance if you are looking for a little bit of that. I would go with some lighter weight wheels.
Good luck
Jake
Old Jan 25, 2010 | 08:17 AM
Danteg's Avatar
Me too i vote for 18'' maximum if you don't want to sacrifice the ride !
Old Jan 25, 2010 | 08:21 AM
Tire size has a lot to do with it too, I don't care if you're riding on bags or stock springs. Of course, that is totally subjective based on your preference and your tolerance for ride quality, just like the "what size is perfect on a 5th Gen" debate. I went from 235/40/18 to 245/40/18 and while I did sacrifice some cornering stability, the ride quality improvement is immense. So even within a particular diameter whether its 17, 18, 19, or 24, get the right tire for your needs and it'll help your ride qulaity.
Old Jan 25, 2010 | 09:28 AM
Shift_Max's Avatar
Good luck
Jake
Like it was stated, tire size is what makes the difference.
19 inch wheels with a proper tire size will be fine.
Old Jan 25, 2010 | 10:45 AM
Scottwax's Avatar
...and expensive!
Lightweight wheels in that size definitely aren't cheap. Besides, OP didn't want to hurt ride quality. 17s with all season radials would work best if ride quality is the primary concern.
Old Jan 25, 2010 | 10:49 AM
Shift_Max's Avatar
I didnt see the OP state his price range.
ah2002
Mar 9, 2016 01:42 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
wingsfan24
Aug 15, 2015 07:35 PM
Max8
Aug 15, 2015 07:06 AM
09maxshawn11
Aug 9, 2015 01:13 PM
