Brand new Fogs already cracked!!
Old Jan 25, 2010 | 08:05 AM
hot_wax_tree's Avatar
So im kinda ticked off cause I just spent $120 on a pair of fogs on Ebay and got put them in. now a month and a half later.....I was gone for 2.5 weeks in that time. both my fogs are cracked. my car sat out side that whole time and was never run, could that be the problem, cause durring the time I was in costa rica we up here in minnesota had literally -25-30 dagree wheather thats not including the wind chill. could this have effected the fogs.
BTW I have a 02 SE
Old Jan 25, 2010 | 08:29 AM
The6spdMax's Avatar
Wow, that sucks. Any warranty? Even though used OEM fogs are somewhat hard to find, but I would rather wait and spend the money for them.
Old Jan 25, 2010 | 09:20 AM
is the glass thicker on thos?
Old Jan 25, 2010 | 09:24 AM
Shift_Max's Avatar
the glass fogs are prone to getting cracked from road debris. Most people put clear film to protect them.
Old Jan 25, 2010 | 01:04 PM
Stereodude's Avatar
A new pair of fogs was like $170 from ABC Nissan about a year ago if you bought the kit to add fogs to GXE Maxima's (which came with none).
Old Jan 25, 2010 | 01:29 PM
The6spdMax's Avatar
Not sure about thickness, but I would assume better quaility vs ebays. My car has 90K on it and orginal fogs are not crack, but I am thinking about buying Lamin-X.
Old Jan 25, 2010 | 03:52 PM
cmd26's Avatar
pics, i would like to compare them to my cracked fogs actually i have a hole in my passenger side fog.
Old Jan 25, 2010 | 04:09 PM
MaximusMorpheus's Avatar
I bought some ebay fogs about 8 months ago, still holding up good...no cracks...they look the same as OEM's to me...
Old Jan 25, 2010 | 04:39 PM
mandyfig's Avatar
Better to slap a protector on it. Like a plastic cover. Will protect from rock chips.
Old Jan 25, 2010 | 04:45 PM
beefy23b/97's Avatar
Could just be cheap glass. Sometimes it is worth paying the stealership price for OEM.
Old Jan 25, 2010 | 05:13 PM
knight_yyz's Avatar
Toolie
Call DAve B, price is 170 for the pair if you ask him for the kit
Old Jan 26, 2010 | 05:24 AM
mandyfig's Avatar
The fogs are molded from PC, Polycarbonate. Same material as your eyeglasses. Tough and scratch resistant. Not all polycarbonates are equal. The aftermarket uses lesser quality PC.
Old Jan 26, 2010 | 05:25 AM
mandyfig's Avatar
As well as your headlamps. They are PC. Headlamps receive a clear coating for UV and scratch resistance. I have seen a Japanese factory apply this coating.
Old Jan 26, 2010 | 05:43 AM
NissanMan97's Avatar
ill buy your cracked ones if you get a new set
B
Old Jan 26, 2010 | 06:20 AM
vball_max's Avatar
The 00-01 fogs are plastic. The 02-03 fogs are glass.
Old Jan 28, 2010 | 10:15 AM
Stereodude's Avatar
This is what my fog lights looked like after 7 years. They both had holes and were destroyed.
I replace 'em with new OEM ones and put the 40 mil Lamin-x on 'em.
So far, so good.
Old Jan 28, 2010 | 10:41 AM
Mizike's Avatar
I did the Lamin-X thing a while ago. They Lamin-X ended up turning yellow/brown from getting so hot. I ended up pulling it off. Good luck with that
Old Jan 28, 2010 | 08:23 PM
CMax03's Avatar
Yes! it's thicker....Check with Courtesy's full kit which includes the stalk, both lamps, relay for about $120-140... next time apply the protective laminate film on your lamps....this subject is all over the org and apparently you didn't search or read up on staying away from those EL' Cheapo Ebay foglights........ Mine were cracked within the first month of me buying my 2003 and I installed the Courtesy Kit 7 yrs ago with that potective laminate film and everything has been fine with no problems nor defects....
Old Jan 28, 2010 | 08:27 PM
CMax03's Avatar
High wattage bulbs or extended periods of time with foglights on and no airflow.....
Old Jan 29, 2010 | 05:49 AM
Mizike's Avatar
CMax03, youre probably right. Ive been in an accident that totaled my ride because "someone didnt see me", so I run with my headlights and fogs on ALL the time. Also, Ive been running PIAA bulbs for years and they seem to get pretty hot. As mentioned above, I ended up pulling off the Lamin-X, but ironically enough, the adhesive filled in the cracks and sealed them up. There is not any moisture in them and theyre still havent blown. Also, I have one aftermarket "Depo" foglight and one OEM foglight and both ended up cracking. Honestly, I think its a horrible design to use glass for foglights when they are susceptible to cracking from road debris.
Old Feb 10, 2010 | 08:52 PM
I did search and when I made the thread it was when search was bringing up threads from 03 and really old ones
doctorpullit
Jul 20, 2019 09:31 PM
Excalibur23
Oct 13, 2015 04:33 PM
meccanj98
Sep 17, 2015 08:28 AM
