Cattman 3" Catback Exhaust - Order Here!
Old Jun 16, 2010 | 11:30 PM
  #761
crystalline's Avatar
Originally Posted by Cattman
Just my humble opinion, but I think drone is, for most people (with a realistic perspective on the trade-offs of performance parts), irrelevant for a 6MT. Sure, you can select a small rpm range and hear the drone, but its so simple to avoid it with a manual tranny.
Brian
Again I think people are posting when they first install the exhaust and talking about a lot of loudness and drone (that's what i did ). The drone was ridiculous for the first two days then it quiets down significantly.
As for why this happens I'm sure someone else can explain the science haha.
Old Jun 16, 2010 | 11:35 PM
  #762
the_joow's Avatar
after a couple days the inside of the tubing accumulates carbon deposits witch somewhat muffels the sound because it's not reverberating of of hard steel, it makes the walls of the inside of the piping a little "softer".... that also aplies to the inside of mufflers, resignators and catalytics...
Old Jun 17, 2010 | 12:07 AM
  #763
CMax03's Avatar
I found drone to be present @ 60-70 mph when tipping into throttle trying accelerate, it's not that bad!!!! That's part of the tradeoff for more performance sometimes,....... but I'll be attacking that problem in the next 2 weeks with 2 different products....it's that spare tire recess that acts kinda like a bass drum....I found shifting the A/t manually @ 3000-3500 rpm to sound really sexy as hell....We've driven this car for 3.5-4.0 hrs from Houston, Tx to Lafayette, La at least 3 times....My wife even made the trip once by herself....@ 70 you can hear it a little once @ 75 mph it quiet enough to sleep....The law made 3 videos with in cabin cruising on youtube guys......
Nmexmax call Cattman and notify him of the problem, he'll get one too you but in the mean time an ole school U clamp will work fine.....Good Luck
Old Jun 26, 2010 | 04:28 PM
  #764
Rods03Max619's Avatar
Damn people come on order these things they say these are the best exhaust for your Maxima! And I want to get mine ASAP so come on !!
Old Jun 26, 2010 | 07:56 PM
  #765
Maxterror's Avatar
Just curious about some things here
...I saw something about this being limited
- Is it still available IE:stock?
- How come I don't see the 3" on the actual cattman site
- How much in total should I expect to pay shipped to Canada...specifically Mississauga Ontario
- Is the demand really high right now , should I expect > 4 weeks for shipping ?
I'd be willing to place a deposit on an order ( if that's needed to confirm ) , the Friday of next week if things work out.
Old Jun 26, 2010 | 08:26 PM
  #766
Grand_hustle17's Avatar
^^^ the website is very rearly updated and its best to just call brian for what you want... there's not even headers listed...
Old Jun 26, 2010 | 09:53 PM
  #767
quickhuh's Avatar
just a quick question, will this bolt up to a stock cat? or is there a need for a aftermarket cat also?
Jay
Old Jun 26, 2010 | 10:03 PM
  #768
...... its listed as a bolt on catback so it will "bolt" to a stock cat... piping size may be different but the flanges still line up
Old Jun 26, 2010 | 10:10 PM
  #769
jowo9's Avatar
Just thought I'd post a little update on my system. Just last night, I did a rough timing of my 0-60 time with my new full Cattman setup (headers, fastcat, and 3" cat-back). Before the new system, I consistently got rough measurements in the 7's, and now I'm very obviously getting times in the 6's. This is all untuned with an automatic, so I'd say these are good results. I love my Cattman setup. Great quality, sound, look, and performance. Hopefully now I can afford to dyno tune someday......
Old Jun 26, 2010 | 11:27 PM
  #770
CMax03's Avatar
There's definitely a difference in the midrange for sure.....I still think frrom a standstill my Cattman 2.5" bpipe/Oem rear muffler setup had a stronger 60' er and lit the tires up from a standstill much easier than the 3", but once @ speed the 3" really pulls hard as hell and I measured my 0-60 mph times in the 6 second range once the 3" cb was installed. I really love this setup as well.....
Old Jun 27, 2010 | 03:14 AM
  #771
tedo007's Avatar
faster than you think
60 to 80
Old Jun 29, 2010 | 12:19 PM
  #772
Sealander's Avatar
Just talked to Brian and put in my order! One more order is needed!!!
Old Jun 29, 2010 | 12:52 PM
  #773
NmexMAX's Avatar
dot dot dot ...
Come'on guys ... Do real measurements .
Using the signal from my VSS, I was able to get a 6.3 0-60. Not bad for me, since I'm @ about mile high elevation.
Old Jun 29, 2010 | 04:10 PM
  #774
CMax03's Avatar
I used my Gtech.......
Old Jun 29, 2010 | 10:30 PM
  #775
CMax03's Avatar
Have you measured the extra airflow with the 3" catback? Can you feel the power increase and is it measureable with your instrument(s)?
Old Jun 30, 2010 | 12:04 AM
  #776
Maxterror's Avatar
Gonna try and give him a call on Thursday if I can but probably Friday afternoon. Sent some msg's but no reply.
Old Jun 30, 2010 | 06:31 AM
  #777
NmexMAX's Avatar
dot dot dot ...
Funny you asked, I'm such a slacker, just got it installed last night. Took my time, and it took a few hours after work Monday and last night. Stripped a screw so, out came the grinder, and it would happen to be the one over the rear axle area, what a *****.
Anyhow,
This thing is insane, and well, you know me fellas, I'm the first one to ask for results, first doubter, etc. I question everything.
So, fitment wise my Gen I headers seem to sit further back than the Gen II’s or even Gen III’s. Even when I got my first Cattman B-pipe, it sat further back than I thought it should have. Where the piping turns 90º before the axle, it rests right up on heat shield for the fuel tank. . Same with this, and of course, it’s larger piping so it's a bit tighter, but surprisingly I don’t have any banging/rattling ... yet. Seemed tighter than it should have been, as in I probably should have seen or heard something, but still have yet to. Yes I did install the piece w/ the welding mark facing the sky nearest to the FastCat. Another plus for me was that my groceries don;t smell as if the came from a 72 Chevy, since I now am rocking the Fastcat, before, no cat.
Initial thoughts were WOW. No rasp, and that’s essentially all I care about WRT sound.
So 1st goes through, traction breaks past 5K, 1-2, loss of traction way more than usual. And of course, I could say since it (fitment was so tight) could have been keeping the engine in its place far better than usual posing more mechanical rigidity. Not likely, since after the entire unit was installed, I did notice it was still floating, as it should be. So I’ll take that as a power gain and not a pseudo tightening up, no way that’s possible considering the length of the system and momentum (no rigid braces, etc) and the fact that it’s bolted in more than 1 piece (i.e. better flexibility), no to mention the flex pipe. So no, that was pure power gain.
Ok, and I DID see more airflow (~3-4% peak, need to excel some graphs to see the entire picture). I hardly drive my car any more, so the noise might not be so bad. I did at one point remember having insane drone at the same RPM’s with my A32, so I guess I’m used to it. Though this isn’t that bad, and there is no rasp, which is effing awesome.
Alos, I do recall CMax stating that you thought you may have lost a litt,e say for a 60’ .. but, that’s what the 3” MAF housing is for, . As has been stated for at least the past 5 years, it’s the cure for laggy T-response. Ok shat I’m done.
So, take it from me with a grain of sugar or salt, maybe a clove of garlic since I am one of the if not the 2nd most picky about sound on this forum.
Old Jun 30, 2010 | 09:10 AM
  #778
The MAXX's Avatar
thank you for that response NmexMax. My excitement builds daily on getting these into production.
Old Jun 30, 2010 | 09:14 AM
  #779
Deckdout2's Avatar
Play with my balls
Anyhow,
I don't believe you.
Old Jun 30, 2010 | 10:50 AM
  #780
NmexMAX's Avatar
dot dot dot ...
I didn't believe myself.
Old Jun 30, 2010 | 08:20 PM
  #781
CMax03's Avatar
testing, couldn't respond to anything on the org for about an hour guys...nice reply NMEX, ur almost back to 100% of yourself.....LOL!!!! My 60' is usually 2.1sec b4 the 3" and ES Motor mounts.....
Old Jun 30, 2010 | 08:55 PM
  #782
em2_walsh's Avatar
Really fighting not to buy this... shouldn't spend the money... its my daily driver... but I want it so bad.
Someone justify it to me.
Old Jun 30, 2010 | 08:59 PM
  #783
perkman87's Avatar
in the 6's and 7's thats weird, I have the same mods and Im hitting a constant 5.8 0-60.......... Automagic as well.
Old Jun 30, 2010 | 09:10 PM
  #784
jowo9's Avatar
Yeah well I don't know about you, but I'm 3000ft above sea level. So that could explain why I'm in the 6's. Oh, and those are just my stopwatch times. How do you accurately measure 0-60 time? I'd love to do that. Oh, and you're tuned! I am not.
Old Jun 30, 2010 | 11:07 PM
  #785
CMax03's Avatar
Screw your 0-60 times what's your 1/4 mi. times so that thread can end with you chasing the OP 13.84 sec/1320ft times.....it's still jam packed! I'll redo my 0-60 times soon and launch it harder than I did to get that low 6 sec 0-60 mph time!
Old Jul 1, 2010 | 06:03 AM
  #786
Deckdout2's Avatar
Play with my balls
You'd better subscribe to that review post, cause you know you'll be asked about it later on down the line, and you'll reply with, "I've already mentioned it before on here, and I'm not going to do it again."
Old Jul 1, 2010 | 06:24 AM
  #787
NmexMAX's Avatar
dot dot dot ...
I tapped my VSS from my ECU, wired that signal to my PLX Logger, read the FSM about the speed signal (what frequency means what speed in MPH), did some test runs to verify ...
Very true, I've tried to lighten up a bit lately though. Let's see how long that lasts. I tend to try & stay out of those threads that are itching for my input.
Anyhow, little update. Went to Lowe's last night to check out some t-stats for the house, (Central air going into today, the evap cooler was FTL).
And well, yes, fairly loud down low but insane sound up top. Once again, I was always jealous reading about when 4AT's broke traction when flooring it, now it's a common occurrence, steering wheel goes crazy, it's awesome, and the insane wheelspin from 1-2 ..
Got a few more rattles and stuff, but strangely enough, not when shifting, no banging.
Old Jul 1, 2010 | 06:56 AM
  #788
perkman87's Avatar
I could be wrong but thats whats on my drag slip correct..... I was having an issue with it shifting into 3rd, which is fixed now (over run clutch pack solenoid) so I am at about the same time for 1/4 mile most likely. with 19" wheels lol
Old Jul 1, 2010 | 10:11 AM
  #789
jowo9's Avatar
Huh. It seems those solenoids go bad fairly often. I just replaced my solenoid pack for a 1-2 slip/flare, and it fixed that.
Oh, and perkman, did you ever drive around untuned? If yes, what was your increase in power/performance when you tuned it. Just wanna know your personal experience. I'm enjoying the added power of my Cattman setup, but I can't afford to tune just yet.
Old Jul 1, 2010 | 10:16 AM
  #790
NmexMAX's Avatar
dot dot dot ...
Speaking of which I haven't even looked at my AFR, I do know the MAF is seeing more air, so who knows that means.
Old Jul 1, 2010 | 10:30 AM
  #791
perkman87's Avatar
I GAINED 15 HP with a/f tune
Old Jul 1, 2010 | 12:42 PM
  #792
tedo007's Avatar
I've put over 6K after I got it installed. Anything above 2K and anything below 2.8K it's loud. So I be cruising 60mph you barely hear the exhaust.
Old Jul 1, 2010 | 12:43 PM
  #793
NmexMAX's Avatar
dot dot dot ...
Jesus man, how many miles do you drive a day?
Old Jul 1, 2010 | 12:51 PM
  #794
tedo007's Avatar
Ha, I drive a lot. Specially I try to go to track every Friday. Track is almost an hour from my place. You'll get annoyed by the speed because auto going to be little higher rpm.
Old Jul 2, 2010 | 09:20 AM
  #795
NmexMAX's Avatar
dot dot dot ...
Does anyone else have Gen I headers? This butting up against the heat shield making contact with the fuel tank has me a bit
Old Jul 2, 2010 | 09:28 AM
  #796
tedo007's Avatar
I don't know about cattman headers. I got OBXv2 and they have problem for my cattman 3" . They make my exhaust hangs low little. I had to remove the those two plate that goes underneath the exhaust. It makes me worried a little.
Old Jul 2, 2010 | 09:32 AM
  #797
NmexMAX's Avatar
dot dot dot ...
But is it stacked up against the tank at the 90*? Or just hanging low?
Old Jul 2, 2010 | 06:24 PM
  #798
wyche89's Avatar
Without reading through the 20 pages of this thread, I'm sure somebody has done a before and after dyno with this setup already, right?
Old Jul 2, 2010 | 08:04 PM
  #799
tedo007's Avatar
I have solution for you I don't know if you like it. I'll take a picture and show you what I did with problem that you have. It's dark right now. Tomorrow I'll take some post on here.
Old Jul 2, 2010 | 08:05 PM
  #800
tedo007's Avatar
I'm doing the dyno as soon as I get the crank sensor changed. Probably in a week.
