wtf??
Old Feb 9, 2010 | 06:24 AM
soto2635's Avatar
wtf??
this morning i wento to get in the car and as i was pulling out of the parking spot it started jerking and thw rpms were low as if it was about to turn off what could it be i dont have a ses light or anything like that ? it only does it on cold days
Old Feb 9, 2010 | 06:38 AM
tdabboud's Avatar
I had been having this same problem recently. What seemed to work for me was to just let the car warm up for a little bit, instead of taking it right out. The jerking has stopped since.
Old Feb 9, 2010 | 06:43 AM
soto2635's Avatar
really?? it had stop for a while but today it came back and cought me off guard i almost hit another car
Old Feb 9, 2010 | 06:47 AM
NissanMan97's Avatar
it is cause you car is to cold....you should let it warm up...this should be obvious seeing as how you can do damage to the engine if you run it hard when its cold
B
Old Feb 9, 2010 | 07:00 AM
Rochester's Avatar
Sounds more like one of your ignition coils is dying. Your ECU may have recorded the problem code, even though the SES didn't go on.
BTW, it's OK to put descriptive information in your thread title. Your thread will get more attention, and you'll have a better chance at getting appropriate feedback.
Good luck with the rough running. I know that helpless feeling; it's very frustrating.
Old Feb 9, 2010 | 07:06 AM
tdabboud's Avatar
Yeah i think its most likely just not warmed up enough. Definately try to warm it up and see how that does and let us know. One time i didnt let it warm up and the car was jerking and it ended up shutting off as i was pulling through an intersection. Last time, i ever take the car right out ha!
Old Feb 9, 2010 | 07:12 AM
tigersharkdude's Avatar
i had this same problem the other day in my 4th gen. i was like WTF. after about 5 min of idle it smoothed out
Old Feb 9, 2010 | 07:59 AM
spydermonkey's Avatar
I've had the same issue. It only happens when shes cold and I drive right off. You don't even have to be rough on her for it to happen. I get her warmed up appropriately now and drive her nice till she gets all hot and bothered...then I go for the gusto! 01' AE 5sp...might have helped to know what you were rolling with in your post as well. Good luck!
Old Feb 9, 2010 | 08:34 AM
Colonel's Avatar
Old Fuddy Duddy
In an 00-01 I know that tends to be the IM gasket. I replaced mine and the "bucking" went away. It, too, was a cold only type issue.
Old Feb 9, 2010 | 08:43 AM
Rydicule's Avatar
Don't you know who I am?
Where do you guys live, Antarctica?
Unless the temperature is sub-zero Fahrenheit, you shouldn't "need" to warm the car up for it to operate properly. I would check for problem codes.
Old Feb 9, 2010 | 08:44 AM
Rochester's Avatar
This.
Old Feb 9, 2010 | 08:45 AM
Colonel's Avatar
Old Fuddy Duddy
On the 00-01 (at least mine) the bucking was brutal, but no codes. Replaced the gasket on DaveB's recommendation and the problems went away.
Old Feb 9, 2010 | 09:19 AM
Rydicule's Avatar
DaveB is the man
Old Feb 9, 2010 | 10:47 AM
AEMAXIMA01's Avatar
This.
Exactly. We had a stretch here in KS about a month ago when temps didn't get above 10 for well over a week and dipped to almost -10 at night. I had no trouble driving around in my car. It's not the cold. Something else is the problem. Call up DaveB and ask him the same thing Colonel did.
Old Feb 9, 2010 | 11:08 AM
I guess we spare DaveB the call at this point because it sounds like it's been summed up as the IM gasket. It also sounds like it's only really apparent when it's cold that it may need replacing as shown by the bucking. Thanks for the info...sounds like a good spring project seeing as how it's not that bad on mine and only really on days under 15 degrees or so.
Old Feb 9, 2010 | 12:58 PM
J-Rod's Avatar
Cars to cold, let it warm up lol... Its actually better to get in and go.
It is the IM gasket, they were ****ty from the manaf. and leak making your car lean. It will buck, mine has for about 5 yrs now and is related to cold. When you start to detect the buck let of the gas and slowly back into it and it won't do it again, switch gears and it will want to buck again, back out of gas and slow back in and it won't. Rinse and repeat. I will eventually replace the gasket.
Old Feb 9, 2010 | 02:14 PM
soto2635's Avatar
thanks guys
Old Feb 11, 2010 | 07:22 PM
soto2635's Avatar
how much does it cost to replace that?? more or less
Old Feb 11, 2010 | 07:23 PM
soto2635's Avatar
who is this daveB u guys speak of? sounds like he knows his stuff
Old Feb 11, 2010 | 07:29 PM
Colonel's Avatar
Old Fuddy Duddy
got the gaskets from DaveB...there were a couple that I replaced as I tore down to the IM gasket. The IM gasket was like 25 bucks, I think.
Old Feb 12, 2010 | 06:56 AM
boost4age's Avatar
yeah ditto
Old Feb 12, 2010 | 01:09 PM
e-subliminal-2's Avatar
Its better to get in and go?.........
Old Feb 12, 2010 | 03:00 PM
LongIslandMax's Avatar
He's the parts guy for SouthPoint Nissan. Deffinatley the guy to go to for any replacement parts. Never have personally done buisness with him, but I hear nothing but great things:http://forums.maxima.org/dealership-...st7404210.html
Old Feb 12, 2010 | 03:28 PM
Feldman's Avatar
my 00 does this too, i am fine if i am accelerating or under compression but if i am coasting and the pedal is just right it stutters kind of. only until it starts to warm up though. Am i still looking at an IM issue?
Old Feb 21, 2010 | 08:38 AM
soto2635's Avatar
wats does this cost if i take it to a shop more or less?
Old Feb 21, 2010 | 09:36 AM
KBCobra's Avatar
When this happens to me, I throw the car in park, turn it off, turn it back on, and let it warm up for a bit before I move it.
Old Feb 23, 2010 | 08:21 AM
soto2635's Avatar
well i went out this morning to turn on the car and it died on me i had to give it gas for a bit till it warmed up, anyway i called a local shop to see how much the charge to replace the IM gasket they wanted $633 wtf!! crazy i might have to go to mexico since im so close to get it done.
Old Feb 23, 2010 | 04:34 PM
Maxxxi69's Avatar
my car does the same thing when its too cold.
the question i have to ask is, why only does my maxima do this?
possibly maybe a factory problem?
Old Feb 23, 2010 | 08:08 PM
Feldman's Avatar
does what? 3 similar but different problems have been brought up in this thread
Old Feb 24, 2010 | 06:49 AM
essential1's Avatar
My axles cry for mercy...
Mine does the same exact thing. (01 dek)
I think what happens is the gaskets are hard when they're cold and with them being bad, they dont seal properly. When they start to warm up, they soften up just enough to seal the IM. But this is just my stupid mind thinking stupid thoughts. I'll change them when I'm not so lazy.
Old Feb 24, 2010 | 10:16 AM
ButtaMax's Avatar
I always give my car 10 mins minimun <40 when sitting overnight, about 3/5 when warm.
Hell we are talking about 7-10 yr old cars!
Old Feb 24, 2010 | 11:05 AM
Colonel's Avatar
Old Fuddy Duddy
What a waste of gas! Mine starts up perfectly fine and I give it about 30 seconds and drive under 2k until I get about 1/2 temp going then its normal driving. Mine sits outside ALL the time and starts perfecting fine at <0.
You are fuel dilluting your oil and wasting gas. That warming up does nothing other than give you creature comforts. There should be no reason to warm up a car like that.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
