02-03 ECU vs 04-08 ECU
What is the main difference in these different generations of Maxima ECU's?
Is it that the 04+ ECU's incorporate CAN?
I figure the 04+ ECU's are more similar to the 350z ECU, as I remember reading somewhere that you can use the 350z Osiris on the 04+ ECU's but not the 02-03 ECU's.
What I'm getting at is, Cobb makes an AccessPORT for the 350z, and I'm curious if this is compatible with the 04+ Maxima ECU's and maybe the 02-03 ECU's.
Also, If I had access to a Consult II, would I be able to use an 04+ Maxima ECU in my 2002 by just getting the NATS/whateverelse switched over and a simple harness repin?
I don't know about anything else, but you will need a 6th gen knock sensor. I ran a '05 engine in my '02. It operated correctly (except for my problem with all 5.5 gen ECUs. They're slow as dog **** in the heat).
I would assume that everything should work since the whole engine is basically identical.
Only reason I ask is because of the apparent surplus of tuning options for that ECU compared to the 02-3 ECU.
Anyone know if the AccessPORT for the 350z will work on an 04+ Maxima?
I just installed an AccessPORT in my friends 06 Si and I really like how it works. They basically have pre-made maps for any combination of mods you can think of. Only minor tuning is required.
Also, I believe it tunes the VTC and ignition timing as well.
Swapping a harness isn't really a big deal to me, as long as it is worth while.
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
The 04+ maxima ECUs have the same connectors and memory/etc as the 350z ecu... opens up a lot of PNP options.
UTEC is PNP on the 04+ Ecu.
Osiris works on it.
Haltech and other companies make easy patch harnesses for it.
I'd go with a 04-06 6 speed ECU + Osiris if I was doing a full swap on an earlier gen maxima.
Osiris works on it.
Does the eeprom in our 5.5s have any identification on it? If we know what it is and can find a larger capacity rom and replace ours...
Or have an ecu flashing comp do it for us if they have said eeprom. Then osiris would work as it's a limitation of capacity on ours (so i read).
If it was a long time ago, it may not have been supported then.
I was always under the assumption that the actual processor was different and used a completely different architecture and that's why no one has really been able to do anything with it except Technosquare. I could very well be wrong.
I really don't know enough about the architecture of the ECU to make assumptions, but couldn't someone just make a dump of the software/firmware and edit the hex values/addresses for the rev limit and whatnot? (That is, if anyone knows what these values are)
I'm an Electrical and Computer Engineering major so I have access to a bunch of equipment in the lab, and I have access to a bunch of smart people also.
If someone could point out what chip needed to be dumped, I may be able to get it done for them and post back the data...
As far as dumping an image of the 04+ software onto the 02-03 hardware, I have some doubts. It most likely uses different hardware, seeing as the ECU's pins are completely different.
*Reminds me of my Xbox modding days...
I read something where it was said that osiris wasn't the limitation and the incompatibility was due to the eeprom being too small and couldn't hold the modded roms.
Maybe I'm wrong, idk, but if that is actually the case, then I don't see why a larger chip couldn't theoretically work.
Also, if a dump of the ROM was achieved, it may be possible to make a "mod chip" of some sort.
It could just be soldered in or be pressed directly over top of the EEPROM (depending on the kind of chip) and overwrite the desired values in the stock EEPROM.
If Technosquare can figure this out, some people on here can also.
That could work.
We could find a similar but larger EEPROM and just dump the firmware on to that one.
This is assuming that the 02-03 has the same memory addresses as the 04+.
Anyone have pics of the inside of the 02-03 ECU?
At this point, I don't even care Utec and Emanage look lame as hell once I read about osiris. I've got nothing against TS, but I'm not paying $500 for something I can't readjust myself and will suffer down time from.
If I could get all the 04 maxima parts (ecu, nats, harness, etc) I will pay someone a few hundred dollars to install the **** haha.
I'm also getting jealous of sparks and jay pee b/c I want those numbers, but can't without this!!!!!
Yeah, otherwise, we're screwed b/c osiris would be never give support (unless a ton of us did it).
At this point, I don't even care Utec and Emanage looks lame as hell once I read about osiris. I've got nothing against TS, but I'm not paying $500 for something I can't readjust myself and will suffer down time from.
I'm sure they already made up for their R&D tenfold.
A re-flash should cost like $150.
And, If I remember correctly, you can disable NATS and all that mess with Osiris, so all you would need is the ECU, plug, and Osiris.
I saw a video somewhere of a VQ35 running on the ground. Just a fuel pump, tank, battery, and ECU.
Here's the vid:
http://www.youtube.com/watch?v=YtcCPtLBXvI
(It is using a Z Fever ECU?)
Edit:
It sucks because my friend used to be a Nissan tech and he had unsupervised access to the Consult II(He got laid off). I think you can just swap the NATS over with that. TBH, I am not even sure what the NATS is or does. I'm guessing it has to do with the transponder or something.
And you're saying I need to go find me some nissan tech friends.... good idea
And I actually do have a 6th gen IM haha
I have an idea if it doesn't sound too stupid.
If Osiris can disable all the BS in the ECU, would it be possible to get it to function correctly as a piggyback (kinda like an EU)? If it will boot and think the car is running, then it should be possible.
Ok, my dumb *** has given it enough thought since I saw this vid http://www.youtube.com/watch?v=YtcCP...eature=related
and I think that ECU could be piggybacked like the utec. Tap/splice all the sensors required (same as utec plus hook a wideband).
The only thing I'm worried about are the unconnected wires. I'm not sure if it'll burn anything out on the ECU from reflection. (maybe hook them up to resistors?)
Obviously, this is far from ideal and people think we should just use an utec or something similar, but I don't like it and not to mention it's no longer supported. I would do this as a stepping stone to use osiris uprev (add on an OBD connector).
Lookin at about $1300 total, I guess.
Yeaf I wish you can pull into Nissan and tell them to give you all the hp the engine can put out for people who are looking for the power or have one of those plug and plays like the American cars do.
What's the need for a piggyback with that ECU? I was under the impression that the ECU was re flashed. I could be wrong.
And yeah, I wish it was like that also Rods03Max, lol. I think with Audi's or something, you can get a re flash right from the dealership.
I see what you're saying (I think).
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
Dasmith
09-23-2015 08:28 PM
QueensMAX
09-15-2015 04:14 AM
