water pump replacement question.
Old Feb 28, 2010 | 03:30 PM
Amave's Avatar
so i found an awsome write-up http://forums.maxima.org/4th-generat...teup-pics.html on relacing the water pump on the VQ30 motor, but one question i haven't been able to find an answer to..
when after remving the timing chain tensioner and moving the crank pulley back counterclockwise, won't the cams " jump " teeth? i mean what's holding tension on the valve springs/cams that don't allow the cams to " jump " timing?
i have done V6 timing chain replacement before, but i have never encountered a chain driven water pump before.
here is an example.
so i'm not a stranger to timing chains i just don't understand the VQ chain design...
thanks guys
Old Mar 1, 2010 | 08:55 AM
Amave's Avatar
well my search has turned up nothing.
my gues is just replace the water pump step-by-step in the write up and i shouldn't have a problem
Old Mar 1, 2010 | 11:07 AM
Nelsito65's Avatar
I did it that way and didn't have a problem. I just made marks on the crank pulley and the engine so I can move it back to the original position.
Old Mar 1, 2010 | 11:28 AM
Amave's Avatar
cool, thanks man, i wasn't sure if tere were any gearheads on.
so pretty much make a mark on the crank pulley at the 12 o'clock position to keep track of how far back and forth to move the crank pulley.
sounds easy enough
Old Mar 1, 2010 | 11:41 AM
Nelsito65's Avatar
IIRC, I made a mark on the 6 o'clock position. Then another one to align with, right on the timing chain cover, just to make sure I would bring the pulley right back to the original position. Finally I just marked where the 20 degrees counterclockwise would be.
00MAXI
Sep 2, 2015 10:23 AM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
