5.5 Gen + 350z Intake Manifold
Old Mar 10, 2010 | 06:15 PM
  #41
PulsarGTS's Avatar
there is a dyno floating around with maxima before and after the IM to Plenum swap...he gained a small amount but it was chopped up to be cooler weather or something. Don't know how his before and after tune was setup but I figure it was a simple VAFC tune w/ wideband type tune IIRC. SSIMs were proven to loose power from some recent info that surfaced recently a couple months back
They've been shown to gain or loose power depending on the car for a while really.
Old Mar 10, 2010 | 06:24 PM
  #42
DrunkieTheBear's Avatar
Turbo'd Saab
They never seem to post any numbers better then a block off plate and power rod removed...
Old Mar 10, 2010 | 08:01 PM
  #43
Gemner's Avatar
Ive seen this too and its what I was referring to when I referenced the vq30 timing equipment instead of the vq35 vtc's. IIRC, the car that was tested did NOT have vtc's which means the cam timing was really just not even close to what this manifold wants
typically gain power with an SSIM over a BOP over 6500 or so. In my experience, the BOP is better is you have stock cam timing, but if you go with z cam timing the SSIM is better. When I had my cam timing adjusted, I picked up 20wtq over a range of something like 3500-5500 with no other real changes
Old Mar 12, 2010 | 12:36 AM
  #44
Gemner's Avatar
for those still following, I just bought a powerlab 3/8" plenum spacer and I will be dropping the engine/trans about 1" to accomodate the extra height. Ill document both here when they happen
Old Mar 12, 2010 | 06:20 AM
  #45
mist max2000's Avatar
thanks gemner.. im following,... how do you plan on dropping it?,.. also.. do you already have ES MM ?
Old Mar 12, 2010 | 10:59 AM
  #46
Gemner's Avatar
yeah I have ES motor mounts. Ill be dropping it by drilling 1 new hole in the passenger side mount and putting spacers and longer bolts in the other three locations. Ill be sure to grab some pics when its done
Old Mar 12, 2010 | 12:10 PM
  #47
Turbo'd Saab
I'd worry about the axles...especially if you are lowered
Old Mar 12, 2010 | 12:19 PM
  #48
Gemner's Avatar
should be fine. I got the idea from the guys that won the NASA nationals in their vq35 B15. If it doesnt blow up their axles I should be more than fine
Edit: plus I already have raxles on both sides for an added safety factor
Old Mar 12, 2010 | 04:51 PM
  #49
PulsarGTS's Avatar
Hmmz your right man. I just took a look at one. Kinda makes me wanna put the OEM manifold back on since I never rev past 5k anymore really.
Old Mar 12, 2010 | 06:09 PM
  #50
Child_uv_KoRn's Avatar
Bad *** Newb
HERETIC
Old Mar 18, 2010 | 10:36 PM
  #51
Gemner's Avatar
well, I dont have much to report here. I did hit the track and ran a 13.7 (previous PB 13.5) and quickly found out that this clutch is toast. My 13.7 run was mostly ok on the clutch, a little problem at the start and a little slip into 4th, but on another run I was not prepared for the launch and my 2-step didnt engage, so i ended up launching at like 6k. Let the clutch out, foot off the clutch gas to the floor and I stayed pegged at 6k for quite a distance before the clutch grabbed at like 5k. That was after even lifting off the gas a little, feathering it but it kept slipping. lol. bellhousing was so hot I couldnt really touch it. I know somebody is going to come in here and say something about losing time, but it must be understood that I sold my VAFC2 since I last ran and my car runs VERY VERY rich for some reason, im talking low 11's AFR. I went thinking if I ran 13.8 or faster it would be a manifold success, since last time I tuned my AFR, the untuned run was sub-200whp and the final tuned run was 230+whp. I figure even with just a basic AFR tune and operable clutch that I would have pulled a 13.3 or so, its that bad. Anyway, when I get the clutch replaced and get some tuning done ill update this. Ill also add pics tomorrow of the engine drop, powerlab spacer, and my version of the MREV2
PS: another member (ulyses) on here rode in my car and when he got out he commented on how smelly it was (gas) and an exhaust tip swipe showed how much more rich im running than he is (TS tuned, so hes probably no higher than 13.0:1)
Old Mar 21, 2010 | 02:09 AM
  #52
Gemner's Avatar
First things first, my version of the MREV2. Now that I see it a little better, it needs the top cut down a little more along with the others
And here you can see the polishing I did. I didnt go too crazy but I hit the problem areas pretty well
Powerlab spacer installed. Some of you experts can probably spot how much lower the engine is by looking at this picture. Its quite a drastic change if you see it in person. Really surprising how much only 1" or less of drop actually looks like
Heres some engine drop shots. These are the spacers i used on the crossmember and the transmission mount (this is the front of the crossmember). I just bought longer bolts (1"), the spacers, and some washers and unbolted, spaced, torqued. Pretty simple.
Last but not least, the passenger side engine mount. I drilled a new hole and put the bolt through at the new hole. Again, pretty easy. You can see where the old bolt hole is compared with the new one
Old Mar 21, 2010 | 07:07 AM
  #53
wow.. that sure is something... thanks for the pics,.. did you 'try' it without dropping first to see how close it would be? or was it that close without the spacer?
also..how are you tuned? wideband and S/Vafc2?
Old Mar 22, 2010 | 10:12 AM
  #54
Gemner's Avatar
It would have rubbed by just a little under 3/8" if I hadn't dropped it. It was pretty dang close. I'm currently not tuned at all. I'll be utec tuned next time it's tuned
Old Mar 24, 2010 | 09:31 PM
  #55
Big J's Avatar
we dropped the motor in the Joe's car (b15 w/ a VQ35) about 1.75 inches at first, lol. The oil pan was kinda low, we ended up raising it up about 3/4 of an inch. It's nice and low.
Curious to see the dyno numbers because we have more than enough room to fit an 350Z intake....
good work on dropping the motor.
Old Mar 25, 2010 | 11:48 AM
  #56
CraigSE's Avatar
Cool thread, I'm going to keep following it!
Old Mar 25, 2010 | 08:29 PM
  #57
Gemner's Avatar
im curious too. cant wait to get some sort of tune and go for it. might be a bit
thanks for the idea. on a side note, the axles survived a 1100 mile drive, so looks like the angle is fine to me
Old Mar 26, 2010 | 08:54 AM
  #58
Big J's Avatar
drive line angles is a myth... anytime you lower a car the drive line angles change, so whats the difference if you drop the motor?
It should have really helped you CoG. Does the car keep traction better in straight line acceleration?
Old Mar 26, 2010 | 11:11 AM
  #59
Gemner's Avatar
hard to say really. When I was running at 253 whp i didnt have much of a problem in any gear keeping traction. Now that im untuned i bet im around 240 or so, so for obvious reasons my traction is a little better. oh and my clutch is slipping bad, so info about hard shifts is out the window. lol, got some stuff to work on over here
Old Apr 4, 2010 | 10:37 PM
  #60
shrek's Avatar
this can be done on a 3.0 just research it
would there be any kind of gain without VCT and a completely diferent timing map(vq30)
Old Apr 5, 2010 | 06:54 AM
  #61
Grand_hustle17's Avatar
Originally Posted by Nismo3112
I did this years ago to my 3.5 4th gen but didn't really notice a difference.
i was going to say the same... VQmonster did it down here and had not much difference if any... good if he did though... it was the same as the SSIM down here
Old Jul 2, 2010 | 11:43 AM
  #62
secondtonone317's Avatar
nycnissans
any updates on this? Great job by the way.
Old Sep 17, 2010 | 01:18 AM
  #63
desoto's Avatar
Well I've been looking around for intake manifold upgrades and didn't exactly find what I was looking for. I've noticed on the new maxima they switched over to a composite intake plenum....So I'm very interested in seeing if it will bolt on to my 02 and what kind of results will come of it? I'm thinking it should produce more power with the smoother air flow and reduced heat transfer. Am I a little late in mentioning this or am I the first?
Old Sep 17, 2010 | 07:04 AM
  #64
essential1's Avatar
My axles cry for mercy...
You're late. It doesnt fit. The heads are different.
Old Sep 17, 2010 | 08:23 AM
  #65
InfinitiI35Rice's Avatar
I was looking into doing this on my I35 but I already ordere my spacers for my stock manifold. oh well
Old Sep 17, 2010 | 08:26 AM
  #66
t6378tp's Avatar
Turbo 3.5
nice thread, any updates
Old Sep 17, 2010 | 06:43 PM
  #67
desoto's Avatar
I'm sorry your answer doesn't convince me very much. It's fine if the heads are different because I'm interested in swapping the plenum, not the lower intake manifold. As long as the ports from my lower intake match the composite plenum ports I should be set......well, I would also have to look at the bolt pattern for the TB.
Old Sep 17, 2010 | 06:49 PM
  #68
essential1's Avatar
That doesnt fit either. I've already tried it personally.
Old Sep 18, 2010 | 01:59 PM
  #69
Rood's Avatar
Told.
Interesting info here tho.
Old Sep 18, 2010 | 05:02 PM
  #70
desoto's Avatar
well, you convinced me for a little while, but then I realized you have a VQ30DE. I don't, my 3.5 has a completely different plenum and I'm assuming the lower manifold is a lot different also, because the bolt pattern is not even close.
Old Sep 18, 2010 | 08:19 PM
  #71
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
He is talking about a 3.5.... Promise ya if this was a bolton affair, I'd have already done it.
Old Sep 20, 2010 | 07:27 AM
  #72
essential1's Avatar
I have a VQ30DE-K in my car and a VQ35DE sitting in a corner in my garage prepped and ready to drop into any 95-01 maxima. I've also helped install the VQ35 your refering to with the black plastic intake manifold into a 4th gen. One of the first in the world to do it. And yes I tried swapping manifolds.
But I dont know anything. Go ahead and waste your money. Buy one, try it, cry that it doesnt work, start a new thread on the .org stating that it doesnt work. Then listen to everyone say "you should have searched because we already know". This is already common knowlege that it doesnt work.
Where have you been?
Old Sep 20, 2010 | 07:49 AM
  #73
MoncefA33's Avatar
Old Sep 20, 2010 | 04:21 PM
  #74
desoto's Avatar
You know what; I'm not trying to step on your toes. I just wanna make sure we're on the same page here. I'm a little skeptical when it comes to what is said in the forums, because most of it is somebody just giving there two cents or guys who know it all, but really don't know anything. And I really don't have the patience to shift through that kind of stuff. I like solid, informative answers with proof to back it up. Also I did do my searching, I would'nt even be having this conversation with you if it was this common on the forums.
Old Sep 20, 2010 | 04:44 PM
  #75
desto, can you use a different txt color, older headers like myself kept the throwback maxima.org theme where the background is white and i cans see a word that you wrote.. just be regular and keep it black bro
Old Sep 20, 2010 | 04:59 PM
  #76
Gemner's Avatar
the dark style has been around since before you joined...
Old Sep 21, 2010 | 05:07 AM
  #77
Shift_Max's Avatar
[quote=essential1;7741697]I've also helped install the VQ35 your refering to with the black plastic intake manifold into a 4th gen. One of the first in the world to do it. [quote]
details?
Old Sep 21, 2010 | 11:08 AM
  #78
Unklejoe's Avatar
hahaha
Old Sep 22, 2010 | 05:50 AM
  #79
essential1's Avatar
Originally Posted by Shift_Max
details?
Slow...
Without anything to control cam timing and the dual VIAS assembles in the IM, etc.. its a waste of time. It loves nitrous though, but what VQ doesnt?
Old Sep 22, 2010 | 06:13 AM
  #80
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/all-motor/3...altima-im.html
MAXSE5SPD
Sep 17, 2022 04:00 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
MaxStock
Aug 12, 2015 08:33 AM
