car pulling when gear changes.
Old Mar 10, 2010 | 10:33 AM
d1max2nv's Avatar
I have been having this problem for about a month now with my 2000 max. when the car switches to second gear it jerks to the left really hard, then straightens back out. It only does this from first to second, or if I am cruising and floor the car. what could this possible be? thanks in advance for any help.
Old Mar 10, 2010 | 10:41 AM
Feldman's Avatar
welcome to torque steer
Old Mar 10, 2010 | 11:23 AM
nismopc's Avatar
Torque steer does not just happen, it's always there.
You might want to check your engine mounts for tears, rips, etc. Also, other potential areas to check:
1. lower control arm & ball joint
2. end links/bushing
3. outer tie-rods
All of this can cause the front end to jerk harder than normal due to loose/worn parts.
Old Mar 10, 2010 | 12:07 PM
kiyakerz's Avatar
3. outer tie-rods
I've actually been having a similar problem, except my car prefers the right when under heavy acceleration. I'll be changing out all of those components for good measure, is there anything else that should be changed? Thanks!
Old Mar 10, 2010 | 12:42 PM
Feldman's Avatar
3. outer tie-rods
or check your tires, a worn/low tire will do it too. In the end the phenomenon your are experiencing is torque steer.
Old Mar 10, 2010 | 01:04 PM
MadMax07SL's Avatar
Front end may be out of alignment as well...I'd start with a front end shop, and see what they recomend.
Old Mar 10, 2010 | 10:43 PM
DennisMik's Avatar
I had bad bushings in my lca and the car pulled to the side during acceleration.
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
