Tokico Illumina setting suggestion
Old Mar 23, 2010 | 04:07 PM
moody's Avatar
Okay, a year ago I had Tokico Blues and H&R springs installed. After a year, I think my front struts (or at least one of them) are going bad, so I ordered a set of Tokico Illuminas for the front. (I'm guessing struts because my tires are having a hard time keeping on the ground when going over bumps or water puddles).
Anyway, any suggestion as to what I should set my Illumina's to in the front? I'm not changing out the rear and this is my daily driver (although I like to take corner's hard because it is fun to do so. lol) My hope is that these Illumina's are better equipped to handle the car being lowered.
Also, when I had my struts installed last year, I replaced the boots and strut mounts. Should I replace those again if it has only been 1 year?
Old Mar 23, 2010 | 04:12 PM
Maximized2000's Avatar
IMO...3 in the front. If you decide to do the rears...set that to 4.
The front are the easiest to adjust so just drive around and see which suits you. Start at 5 and work your way down to the lowest which is the softest setting on the illuminas.
Old Mar 23, 2010 | 04:13 PM
auveeb's Avatar
I have a question, where did you get two struts for the front individually?
I just bought a set of Blues but I'm tossing around the idea of going with illuminas in the front and blues in the back.
How was the ride with blues & h&r springs?
Old Mar 23, 2010 | 04:16 PM
I just bought a set of Blues but I'm thinking I want to go with illuminas in the front and blues in the back.
Idk if they still sell it but I got mine from this place a while ago.
http://www.performancepeddler.com/
Click log in and type in Maxima to get discounted prices.
Old Mar 23, 2010 | 07:09 PM
moody's Avatar
I'll do that. Thanks!!
Old Mar 23, 2010 | 07:17 PM
moody's Avatar
As Maximized2000 suggested, I ordered mine from performancepeddler.com. Just use the code "maxima" when ordering. They were part # BB3188 and BB3189. It was back-ordered but it only took 3 extra days. I ordered them March 18th and they were sent out today.
As for the ride w/ the H&R and the Blues, I like it. The drop isn't as big as what you'll get with some of the other springs, but I didn't want a ricer look. I just wanted to drop it a little and stiffen the suspension some. That coupled with the Tokicos gave a stiffer ride that wasn't too rough. Put it this way... my wife was able to drive it without major complaints!
I should have these installed in about a week. I'll try to remember to come back and post the difference (if any).
Old Mar 23, 2010 | 10:10 PM
a33_ridah's Avatar
i have them on 3 all four corners...
Old Mar 24, 2010 | 04:49 AM
moody's Avatar
Cool, that helps. I'll start with 3 up front and go from there.
Old Mar 24, 2010 | 07:19 AM
Prophecy99's Avatar
4 up front is where the fun begins, I actually never set the rear softer than the front, so Im not sure how it may feel when you have the somewhat softer blues in the rear.
i ride 2F/3R winter months and 4/5 summer months on H&R
Old Mar 24, 2010 | 01:22 PM
NismoAce's Avatar
do you lose a lot of the smooth disconnected from the road luxury feel on the highway?
Old Mar 25, 2010 | 10:04 AM
moody's Avatar
Hard to say... mine is the SE so it was kind of stiff anyway. I would say you definitely feel more of the road though (regardless of SE or GLE).
Old Mar 25, 2010 | 11:34 PM
a33_ridah's Avatar
x2. yup yup to the definite more road feeling.
Old Mar 26, 2010 | 12:07 AM
byrdman164's Avatar
Yeah, you definitely do feel the road more. I had blown front struts on OEM GLE springs, and the car felt like a boat. Even small dips in the road were catastrophic. I put in H&R's and tokico illuminas and noticed a much better ride (obviously since I finally had working struts haha). I've had them in the car sine august of 09, and have no complaints about them at all. Plus with the Illuminas you can adjust them to whatever suits you.
Old Mar 28, 2010 | 03:50 PM
BeSTKePTINdALOu's Avatar
DOES ANYONE KNOW HOW TO ADJUST THE REARS ON THE ILLUMINAS?
Old Mar 28, 2010 | 04:17 PM
johnnyd2k2's Avatar
pull out the trunk liner and get in there with a precision flat head its a pretty tight spot and not easy, I found if you put the rear seats down and lay on your stomach it makes it slightly easier.
I ran mine 2/3 in the winter and 4/5 summer w/ Vogtlands
Old Mar 28, 2010 | 04:19 PM
PulsarGTS's Avatar
I'm running H&Rs in the front and SE OEM rear springs. I usually run 2f1r. I tried 1f and it was super smooth but a bit disconnected. If I end up with some 18"s this summer Ill prolly go back to 1f. I don't drive aggressive with this car so lower setting as good with me.
Old Mar 29, 2010 | 10:19 AM
Prophecy99's Avatar
how did it feel having it softer in the rear? I like to do the opposite and have it softer in the front.
Old Mar 29, 2010 | 02:51 PM
PulsarGTS's Avatar
Honestly not bad at all. The whole time I ran Eibachs ran 3f5r. I just assume OEM SE springs are softer than any lowering spring thus the lower setting. I may try 2f2r tomorrow.
Old Mar 29, 2010 | 02:52 PM
RIGHT ON JOHNNY D! I FIGURED IT WAS SOMTHING LIKE THAT. DIDNT WANNA JUST START TEARING STUFF UP
Old Mar 29, 2010 | 04:14 PM
mist max2000's Avatar
i run 4f/5r in the summer on 18's
and 2f3r in the winter on 16's
Old Apr 24, 2010 | 07:17 AM
MyGray96SE's Avatar
I got my H&R and Illumina setup installed about a week ago. Still tweaking the settings. Went with 2f/2R and it was smooth, but on some big bumps it hit pretty hard. Freeways are still chewed up from the winter. On 1f/1r, I am wondering how the dampers will handle the bigger pot holes...
Old Sep 11, 2010 | 06:44 PM
Doomztown's Avatar
what is a good setting for htechs?
Old Sep 17, 2010 | 10:58 AM
InfinitiI35Rice's Avatar
I usually keep my Tokiko's at 3 in front 5 in back. works out okay
Old Sep 22, 2010 | 08:05 AM
MizzMaxine's Avatar
I'm riding H-Techs 3 all around.
Old Sep 22, 2010 | 08:24 AM
schmellyfart's Avatar
I have mine set at 3 on all corners.
Old Dec 1, 2010 | 01:04 PM
roggeezy's Avatar
I ran 5f 5r when I had mine =]
Old Dec 1, 2010 | 01:31 PM
ColtMax's Avatar
Was running 5/5 but after a few trials, 3F and 5R is a descent setting for summer.
Since I will end up with 17' inches steelies for the winter, Ill try 1F/2R.
Still running OEM springs.
Old Dec 1, 2010 | 01:49 PM
xdsub40's Avatar
I have H-tech springs sitting at my house and after research decided the illuminas are the best route. How is the ride with the h-techs and illuminas as far as bottoming out and how smooth with 3's in front and rear?
Old Dec 1, 2010 | 03:21 PM
maximadave's Avatar
detailerdaveb@gmail.com
3F/5R all the time
Eibach/Illuminas
Old Dec 1, 2010 | 05:39 PM
CMax03's Avatar
Progress 2F/3R super smooth!
Old Feb 15, 2011 | 07:54 AM
SHIFT_6's Avatar
so from what I have read, everyone agrees the illuminas perform well with a drop. However, and I know this is not the "norm" ... I am considering illuminas on all 4 corners on stock springs. With this setup, the ride has to be amazing, am I wrong? Has anyone run this setup?
Old Feb 16, 2011 | 12:58 AM
CMax03's Avatar
It'll still work w/stock coil springs
Peter Paul
Jan 2, 2016 05:18 PM
viperboy
Sep 27, 2015 07:05 PM
lrb6805
Sep 17, 2015 04:49 PM
240tomax
Sep 13, 2015 03:28 PM
