HELP!!! just drove into a deep puddle!
Old Mar 29, 2010 | 06:19 PM
anomaly117's Avatar
As the title says, i just drove through a deep puddle, and i have one of those injen "straws". must have sucked up a small amount of water, cuz it stalled out. and now, as long as the clutch is in, or whenever i try to idle it stalls unless i give it gas. could be a maf i thought, but i took it around the block and got on the gas in a couple spots, and it didnt really choke like a bad maf; it was pretty responsive.
thoughts? maybe this will be ok if it just dries out?
Old Mar 29, 2010 | 07:07 PM
AEMAXIMA01's Avatar
Not sure if this directly applies to you or not. My 01 had this issue a year ago, but I didn't drive through a puddle. Turned out it was the IACV. It would stall at idle but run fine, especially when revving the engine. MAF was fine. It actually fried the ECM along with it. Good luck.
Old Mar 29, 2010 | 09:56 PM
anomaly117's Avatar
thx. ill see how its running tmrw and take a look at the iacv depending. appreciate the input AE. ill lyk
Old Mar 29, 2010 | 10:07 PM
anomaly117's Avatar
jus so everyone knows, this isnt a random issue, this happened THE INSTANT i saw water splashing up over my quarter panels... didnt know the puddle was so deep. so yea. def water related. im drunk cuz im worried about my car.
Old Mar 29, 2010 | 10:20 PM
Feldman's Avatar
Doesn't sound like you did any major damage since it still runs. My money is on the maf, IACV is another good guess, these same symptoms also happen if your car is poorly grounded. letting things dry out may take care of things though
Old Mar 29, 2010 | 11:18 PM
CMax03's Avatar
Clean the MAF sensor it may help! I don't miss that Injen!!!!!
Old Mar 29, 2010 | 11:29 PM
Gemner's Avatar
check your oil for a milky color, if so you got water into the cylinders. If not, you may have ruined a sensor but chances are youre otherwise good
Edit: TOSS THAT INJEN!!! its just on there robbing power and risking the life of your engine. You can make a short ram intake from the parts you already have
Old Mar 30, 2010 | 08:40 AM
StenholmEngineering's Avatar
You guys getting a lot of rain up in MA too huh Anomaly? Thats why i hate cold air intakes! But G/L hope all works out!!!!!
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
