Gah!! Ignition coils are the work of the devil >:\
Old Apr 5, 2010 | 12:29 PM
Amave's Avatar
So this is the 4th ignition coil pack i will be replacing in the past 4 weeks. It seems like every single week a coil pack goes bad. I replaced the #6,5,4, & 3 already ! What gives??? I only saw the silver dot on one of the coils, and who knows when that one was replaced.
anyone know if the coils have been " updated " or will they fail again in a specific amount of time?
reason why i ask is because Advance Auto Parts only warranties them for 1 year, and at 60-70 bucks a pop isn't exactly the cheapest part...
Nissan coils FTL
Old Apr 5, 2010 | 01:01 PM
Nelsito65's Avatar
Some people are lucky enough to just replace one coil pack and they can go on with the rest of them not going bad. When one of mine went down I started replacing all of them as money permitted, even if the rest hadn't failed. My take was that I would prefer the car running with a complete new set rather than having a new coil here and old ones there. I eventualy replaced all of them and they all turned out to be the updated ones. I found out that, on the aftermarket ones, the gray dot is hidden under a silver sticker. They even have what it looks like the nissan "burger" shaved off the stems (perhaps they come from the same manufacturer that makes the ones for Nissan and they shave them off for copyright issues, IDK). I bought them from Autozone and Amazon. Hopefully I won't have to replace them again in, at least, 10 more years.
Old Apr 5, 2010 | 02:10 PM
Amave's Avatar
yeah i hope that if these go bad they will in the next 2-3 years, even that would be acceptable to me considering i have been replacing one just about ever week or other week. i mean it would be so bad if it was a 4 cylinder or if the coils were $40-50 each.....i hope the aftermarket companies had either redesigned them or taken the redesign from Nissan and manufatured them that way.
Old Apr 5, 2010 | 02:17 PM
OOmaxSE's Avatar
Give us the part number for the coils, I'll let you know if they're updated. Or, if they don't have a PINK dot on them then they aren't the latest ones.
Old Apr 5, 2010 | 02:23 PM
Nelsito65's Avatar
I think that only the ones sold by Nissan have the part numbers that you can identify as updated or not.
PINK dot???.. Does that mean that the ones with the gray dots are something like 2nd generation coils?
Old Apr 5, 2010 | 02:39 PM
mandyfig's Avatar
If the packs are being refurbished (remanufactured), where are they getting them (the old ones)?
You do not pay a core charge on the ones you purchase right?
Old Apr 5, 2010 | 02:41 PM
mandyfig's Avatar
There's probably an aftermarket supplier who makes them. I have been into a coil pack manufacturing plant and I can understand what it takes to make them. Very expensive machines doing the wiring or primary and secondary. They do quality work.
Old Apr 5, 2010 | 02:51 PM
Amave's Avatar
very true, i don't get charged a core i just toss the old ones out since they are no good.
i'd like to open one up to see what exactly goes bad in the coil itself.
and i hope that the newer coils with the silver dot, silver sticker or pink dot have had the problem fixed ( so coils don't go bad within a week )...
Old Apr 5, 2010 | 02:57 PM
mandyfig's Avatar
The circuit board probably goes out and not the wiring, just a speculation. There are intricate circuit boards in the coil pack. And very sensitive soldered connections. All exposed to high temps.
Old Apr 5, 2010 | 03:02 PM
mandyfig's Avatar
I will post a cross section of a coil pack for your viewing pleasure.
Old Apr 5, 2010 | 04:36 PM
mandyfig's Avatar
Here you go, enjoy:
Old Apr 5, 2010 | 04:39 PM
mandyfig's Avatar
Closer shot!
Old Apr 5, 2010 | 04:55 PM
Amave's Avatar
well, thats interesting , but it looks nothing like my coil packs.
mine have a skinny boot that is detachable and has a long spring that runs inside the rubber boot to coil. I will have to dig up and old one and take a pic of it, but mine looks nothing like the pics posted.
Old Apr 5, 2010 | 05:09 PM
mandyfig's Avatar
These are not Nissan coils, they are another Japanese car maker, used for show only.
Old Apr 6, 2010 | 07:53 AM
sontakke's Avatar
Where is the circuit board? All I see is the cut section of ferrite core and primary and secondary windings; not much different than what they had on Ford Model T coil :-)
- Vikas
kmitchel
Oct 28, 2015 09:46 AM
iflexsteel
Sep 15, 2015 03:37 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
maxima297
Aug 3, 2015 12:50 PM
