looking for some advice on a wideband 02 . . .
Old May 7, 2010 | 02:35 PM
mist max2000's Avatar
Hey im in the market for a wideband,.. and looking for the best bang for the buck,..hopefully in the 200 dollar range,.. and im going to be using this with an SAFCII cattman headers, and a 2.5" custom exhaust with a test pipe..
i remember someone , either sparks or knightz ,.. said there is a good one that isnt the most accurate but you can data log on it and its reasonable,... which is huge for me...
so.. please let me know what your using and how you like it,..also where you mounted it,.. i think i might weld it in the test pipe just for the ease of installation...
Old May 7, 2010 | 02:47 PM
rroderiques77's Avatar
Demodded and Forgotten
I like my Innovate. I don't have the RPM harness, therefore, I can't datalog. However, it is very accurate.
Old May 7, 2010 | 02:50 PM
essential1's Avatar
My axles cry for mercy...
Where's Monceff?
Old May 7, 2010 | 02:53 PM
shadyonedeath's Avatar
I also have innovate LC-1. Accurate, does the job, but no data logging.
Old May 7, 2010 | 02:54 PM
MoncefA33's Avatar
Originally Posted by essential1
Where's Monceff?
Right here
I've got an AEM that's hooked up to my piggyback controller for datalogging.
Since you're running an SAFC2 (no datalogging/wideband interaface), I suggest running the Zeitronix ZT-2. It's a touch over $200, reasonably accurate and can datalog to your laptop, and log RPM as well so you can tune yourself (without any accessories). http://www.zeitronix.com/ for moar info.
An alternative option is the Innovate Motorsports LM-1 with RPM converter, but this is around $385 last time I checked.
Old May 7, 2010 | 02:59 PM
tedo007's Avatar
faster than you think
I got AEM UEGO for 180 shipped from ebay.
Old May 7, 2010 | 03:48 PM
thanks for the fast response everyone...
Right here
great info.. im going to go do some reading on the ZT-2,.. the selling point for me is the datalog/rpm..thanks..
does the uego datalog to a laptop with no additional parts? persay.. also.. im not a huge fan of the gauge they use with the light that goes back and forth that looks like something doc would have put in the back to the future car,..
Old May 7, 2010 | 03:58 PM
Zt-2 Standard Kit
$279
Zt-2 Wideband Controller and Datalogging System - Model 2010
Cut your tuning time in half!
Includes the Zt-2 Model 2010 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions and 2-Pin EGT connector to retrofit your EGT probe. New data input supports air/fluid temperature sensors, fuel pressure and more! The LCD and ZR-2 Multi-gauge support viewing this new data. Made in the USA
sounds good to me...
now sorry in advance for the dumb Q's monacf ...
I dont NEED the gauge.. if im going to be data logging on my comp and tuning off the charts i make,..is that right? because its 400 with the gauge.. ehhhh ...
do you think any digital a/f gauge would be able to be tapped in or only their product...
also.. any scare in looking for a used one? or should i just lay out the 280 and buy it new w/o the gauage..
Old May 7, 2010 | 04:27 PM
tonedef's Avatar
Innovate Motorsports FTW!
Old May 8, 2010 | 12:22 PM
tedo007's Avatar
There is cable you can make for like 4 bucks and log it. There is How To's on google.
Old May 8, 2010 | 04:28 PM
MoncefA33's Avatar
1) You don't need the gauge, if you're gonna do that. In fact when I tune I read the AFR datalog on my laptop.
2) AFR gauges aren't universal. AEM UEGO and Innovate LC-1 harnesses/connectors are different, for example.
3) I bought mine used, they're just hard to find used.
Old May 8, 2010 | 04:40 PM
NmexMAX's Avatar
dot dot dot ...
PLX R-300. Fairly sweet. You can hook a shatload of different shat to it and monitor in real time.
Not exactly cheap, and IIRC, they've replaced it with something else, newer/cooler.
ZT-2 for you I would think
Old May 8, 2010 | 06:19 PM
knight_yyz's Avatar
Toolie
+1 for the zeitronix
Old Sep 9, 2010 | 09:12 PM
jowo9's Avatar
Ok, I'm gonna bump this cuz I have a question (somewhat noobish) about the Zeitronix ZT-2 wideband. I want a WB that I can datalog with. I was thinking Innovate LC-1, but I don't want to have to tether a bunch of other crap to it (auxbox or whatever) to get the datalogging capabilities. So I'm considering the ZT-2 instead... now here's my question: with the ZT-2 do you simply have to splice into the RPM wire of the ECU (the same as with my VAFC II) to get RPM vs. AFR datalogging? Basically what I'm asking is: how does the ZT-2 get the RPM signal from the car? Thanks for helping me out ... I've had all my bolt-ons for a while, and I'm just getting into tuning, and want to be able to street tune it myself, and not JUST get it done at the dyno place
Old Sep 9, 2010 | 10:03 PM
knight_yyz's Avatar
Toolie
yup, just splice into the tach wire behind the cluster. the software with the zt-2 will log rpm vs afr for you. Very simple.
Old Sep 9, 2010 | 10:24 PM
jowo9's Avatar
Behind the cluster? Wouldn't it be the same to splice into the tach wire that you splice into for the VAFC off the ECU? Like into the wire on pin #34 in this diagram? Would that work too or do I have to splice into the wire behind the gauges? Thanks.
Old Sep 10, 2010 | 05:18 AM
knight_yyz's Avatar
Toolie
cluster is a hell of a lot easier to get at than the ECU, your choice though
Old Sep 10, 2010 | 06:14 AM
NmexMAX's Avatar
dot dot dot ...
And tapping more than 1 signal from the same ECU wire usually doesn't make things very happy. I've noticed this with the ever so sensitive TPS.
Go with the tach wire behind the cluster.
Old Sep 10, 2010 | 01:26 PM
jowo9's Avatar
Ok which one is the tach wire behind the gauges? Do you have a diagram?
Old Sep 10, 2010 | 07:40 PM
Chris Gregg's Avatar
Get Off My Lawn
Just throwing my .02 cents out there. Avoid PLX. My personal experience has been they are crap. Their customer service is even worse. Felt it needed to be said.
Old Sep 10, 2010 | 08:02 PM
tonedef's Avatar
innovate motorsports by miles... check out ebay...
Old Sep 10, 2010 | 08:05 PM
jowo9's Avatar
Anyone? Knight or NmexMAX? D'you know which wire behind the cluster is the Tach wire?
Oh, and I think I'm gonna go the Zeitronix Zt-2 route. I like that it has rpm-sensing and datalogging capabilities without buying the extra stuff (auxbox, etc).
Orrr... Let's say I get the Innovate LC-1. Can I just get the SSI-4 and have rpm datalogging capabilities?
Old Sep 11, 2010 | 11:45 PM
jowo9's Avatar
HA! I found it. So, I'm gonna post it, just in case anyone else is wondering how to wire up the Tach wire on their WB behind the gauges instead of near the ECU. I downloaded a copy of the 2002 FSM, and found out that the Tach signal wire is Pin #16 in the following diagram from the FSM (just in case anyone ever wants to know... now the info is at least out there)
Old Sep 11, 2010 | 11:51 PM
NmexMAX's Avatar
dot dot dot ...
I will add this to the VAFC sticky .. thanks JaeDouble yoo.
Old Sep 11, 2010 | 11:58 PM
jowo9's Avatar
No problem
Old Dec 16, 2010 | 06:26 PM
jowo9's Avatar
I have a question regarding my Zeitronix WB. Where is the best place to splice the power & ground wires? I emailed Zeitronix and they said to splice into the ECU's power and ground, but I'm a bit reluctant to do that because I'm wiring up my VAFCII to the ECU. Anyone have any suggestions? Where did you wire your WBs to?
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
