What is the best intake?
Old May 10, 2010 | 06:05 AM
  #41
merovi's Avatar
GAB
Old May 10, 2010 | 06:11 AM
  #42
Rochester's Avatar
Ryan has a point: GAB is the best bang for the buck.
Or for the price of a coat hanger, if you want to look at it that way.
Old May 10, 2010 | 06:15 AM
  #43
jeff5347's Avatar
so no one sees any validity or comparison regarding the velocity stack. previous to this article i thought it was here-say and marketing ploys. But velocity stacks have been around in the muscle car world forever and as the article shows, The proof really does exist that 1) the SRI is not the top performer (in all cases) and 2) The velocity stack in addition to the CAI the best mod for intakes.
Old May 10, 2010 | 06:17 AM
  #44
NmexMAX's Avatar
dot dot dot ...
JWT POP has one, and that's why I use it.
Old May 10, 2010 | 06:47 AM
  #45
merovi's Avatar
I don't have anything to add on the velocity stack matter but if you are on the fence about an intake and not sure what to do or what route to take I suggest just doing the GAB. All it requires is a thick style hanger, some cutters, and slight elbow grease (bending that hanger could take a toll on you ). Test it out and see if you like it. The GAB is basically a stepping stone. The minimal gains you get from an actual intake I would say are halved to the GAB(no proof just throwing it out there). If you have a GAB and are needing more get an intake. If you do a GAB and it's just not for you go stock. or just keep it!
Old May 10, 2010 | 06:53 AM
  #46
NmexMAX's Avatar
dot dot dot ...
GAB gave me 9whp.
Old May 10, 2010 | 06:58 AM
  #47
Rochester's Avatar
Doesn't the Apexi dry-filter incorporate the air flow principles of a velocity stack by design?
And isn't that why the Apexi is marketed as a couple HP bump over the K&N pop-charger?
Old May 10, 2010 | 07:05 AM
  #48
NmexMAX's Avatar
dot dot dot ...
Over say a Stillen?JWT? Hmm ...
Old May 10, 2010 | 07:16 AM
  #49
merovi's Avatar
Originally Posted by NmexMAX
GAB gave me 9whp.
I meant that usually because when someone does the GAB they don't replace most of the intake setup leaving the tubes and everything stock. So the gains felt, which I agree there are some, are in between stock and a WAI.
Also, maybe you having the 3.5 and I had the 3.0 had something to do with different gain amounts.
Old May 10, 2010 | 09:53 AM
  #50
killer00's Avatar
so what you total gain? JWT Pop means that Jim wolf filter, right?
Old May 10, 2010 | 10:05 AM
  #51
killer00's Avatar
is this filter any good for a short ram? or compared to a JWT pOp?
Old May 10, 2010 | 11:02 AM
  #52
NmexMAX's Avatar
dot dot dot ...
I went from 210 - 233 with lots of area under the curve with the addition of a POP charger & timing advance (+2º from dealer) only.
Here's the JW/Stillen
Old May 10, 2010 | 11:41 AM
  #53
killer00's Avatar
isn't your MAF sensor going to f up because theres no actual filter?
Old May 10, 2010 | 11:51 AM
  #54
NmexMAX's Avatar
dot dot dot ...
That's just a pic of the stack, the filter sits on top of that.
Old May 10, 2010 | 12:49 PM
  #55
essential1's Avatar
My axles cry for mercy...
I need to get a velocity stack ASAP...
Old May 10, 2010 | 12:51 PM
  #56
Rochester's Avatar
NmexMAX, does the Apexi incorporate the air flow principles of a velocity stack by design? Isn't that what sets it apart from other pop-chargers?
Old May 10, 2010 | 12:59 PM
  #57
essential1's Avatar
And while we are on the subjuct of velocity stacks, whats a good place to get one from? And how big can we go before we get too rediculous.
Old May 10, 2010 | 01:08 PM
  #58
NmexMAX's Avatar
dot dot dot ...
I have no clue on the Apex'i .. I'd say just get Stillen?JWT/Apex'i .. whatever works
Old May 10, 2010 | 01:09 PM
  #59
killer00's Avatar
Can you post a pic with the complete setup?
Old May 10, 2010 | 01:10 PM
  #60
NmexMAX's Avatar
dot dot dot ...
Old May 10, 2010 | 01:12 PM
  #61
knight_yyz's Avatar
Toolie
the apexi filter only has a small filter , whereas the velocity stack is 6" wide at the bellmouth so theoretically it should work a little better
Old May 10, 2010 | 05:38 PM
  #62
stockmaximaFTW's Avatar
NOT INVITED TO MAXUS 2010
you gained 23hp at the wheels because of the intake + timing or because you tuned it?
I don't believe any intake will net you 23hp at the wheels on a vq35de....
Old May 10, 2010 | 06:14 PM
  #63
datdude20's Avatar
injen cold air intake ftw!!!!!
. LMAO!!
Old May 10, 2010 | 06:17 PM
  #64
BlackHawk3G's Avatar
What do u guys think about the Injen RD Series Cold Air Intake RD1935P??
Old May 10, 2010 | 06:19 PM
  #65
Grand_hustle17's Avatar
i will give you a pass cause ur only at 10 posts, but searching is still best new youngster, you buy injen moreso for the name as its not a "true" cold air because its behind the radiator (hot air) just make your own or read this thread and see what is out...
Old May 10, 2010 | 06:29 PM
  #66
if you position it correctly it doesn't sit behind the rad fwiw.
Old May 10, 2010 | 06:49 PM
  #67
CMax03's Avatar
I gained 8hp w/ the GAB and 14 more with a JWT POP
Got some dyno charts of that?
Old May 10, 2010 | 09:41 PM
  #68
2kNycMaxima's Avatar
heard injen is bad..i dont know though, I did the GAB on mine.
Old May 10, 2010 | 11:26 PM
  #69
SoonerFan's Avatar
Cletus
yes
  #70
SoonerFan's Avatar
Cletus
<----- misses the good old days with 5th gen was actually moderated...
Old May 10, 2010 | 11:53 PM
  #71
nzelinsky's Avatar
Go with Injen! you cant go wrong for $400 you get like 50hp to the wheels plus they give you a sticker that adds at least another 5! Not to mention it is the best intake if you want to bang out some NOS!
Old May 11, 2010 | 05:58 AM
  #72
Rochester's Avatar
Originally Posted by SoonerFan
yes
Ah, that's what I always thought. I just needed some confirmation with all this talk about velocity stacks.
Puppetmaster pops in every now and then for some cleanup. I think he does a great job when he's around. But overall, I agree the 5th gen forum could benefit from more management. Somebody constant and even-handed... I've been thinking 2slow would be a good candidate.
Old May 11, 2010 | 06:06 AM
  #73
NmexMAX's Avatar
dot dot dot ...
You know me, of course I do. It's in my dyno thread, or one of my dyno threads. Too early for me to be digging them up, since it be a
The GAB was dyno'd on the same day, the JWT was dynoed about 3 months later using th same CF.
I dyno'd the effects of the midpipe too a while back .. 's
No tuning, the only difference was the day, maybe that played into it.
Old May 11, 2010 | 02:53 PM
  #74
you have to admit 23whp is a huge gain...
Old May 11, 2010 | 02:59 PM
  #75
killer00's Avatar
I think that they got a super high, rpm fan that blew alot of air in to the intake for him to gain 23whp. even then.
Old May 11, 2010 | 03:12 PM
  #76
NmexMAX's Avatar
dot dot dot ...
Freaked me out for sure.
Headers in all runs.
Stock airbox~210
GAB ~220
JWT (x2) + 17º BTDC ~230+
Old May 11, 2010 | 03:16 PM
  #77
killer00's Avatar
Did you make that Dyno with Paint or photoshop?
ahahahah
Old May 11, 2010 | 03:27 PM
  #78
NmexMAX's Avatar
dot dot dot ...
ahahahah
I prefer paint, but I just had some coffee so ... yeah..
My KS was being sensitive that day, timing was all over the place.
Old May 11, 2010 | 04:07 PM
  #79
5 ltr. beater's Avatar
even looking at the dyno sheet, it still doesn't make any sense. in all my years playing with machines, ive never seen an intake net you 23whp. i mean, not even V8's see those gains with an just an intake.
i guess there is a first for everything.
Old May 11, 2010 | 06:49 PM
  #80
whats jwt x2? and you had headers already installed but no intake?
