I got my HID....
Old Dec 10, 2001 | 07:21 PM
csyeo's Avatar
I got my HID....
The 2k2 HID I ordered finally arrived. I am going to install it real soon.... but I do face a problem. The connnector for my signal lights does not fit the 2k2 unit. for those of you who have successfully installed 2k2 lights, can you give me the part number of the connectors? Also, if I wanted to change my high beam to PIAA extreme, which bulb type should I choose?
Old Dec 10, 2001 | 09:22 PM
Maximum Velocity's Avatar
Re: I got my HID....
Is there an extra pin that is not making the connector fit? And you would need a PIAA 9005 bulb for the high beam.
Old Dec 10, 2001 | 09:25 PM
BigDogJonx's Avatar
You should have gotta that signal connector with the lights, if not, you need to order that part from DaveB. And make sure you got the other two connectors, like the HID connector and the high beam plug.
Dixit
Old Dec 10, 2001 | 10:53 PM
csyeo's Avatar
Dixit
Well, I have all the signal connectors. The only problem is that the connector for the indicator lights seems to be the wrong ones. it is symetrically opposite of the correct one. I am leaving Town soon and is in a hurry to get the whole thing installed. So i was hoping that I could get it from my nissan dealer in houston.
Old Dec 10, 2001 | 11:12 PM
csyeo's Avatar
Re: Re: I got my HID....
it is not an extra pin... it is an extra piece of bulge that is in the wrong side.
Old Dec 11, 2001 | 03:00 AM
mingo's Avatar
shave that bulge off.. that's what i did..
Old Dec 11, 2001 | 03:59 AM
UMD_MaxSE's Avatar
Got Bent?
congrats
shave that bulge off with a utility knife or a dremel. That's what I had to do... no biggie...
Old Dec 11, 2001 | 11:48 AM
BigDogJonx's Avatar
Originally posted by UMD_MaxSE
congrats
Damn Ghetto riggin is back in full effect I see............. nice........
Old Dec 11, 2001 | 11:51 AM
UMD_MaxSE's Avatar
Got Bent?
yup
Old Dec 11, 2001 | 12:10 PM
BigDogJonx's Avatar
yup
So what wiring plan did you use? did you do the alarm fix?
Dixit
Old Dec 11, 2001 | 12:14 PM
UMD_MaxSE's Avatar
Got Bent?
Dixit
I used your write up to get the wire colors and stuff and then did the turn signals, parking lights, and Xenons just like you did. For the high beams, I decided to go all out and get power directly from the battery so I used two in-line fuses with two Hella relays. Basically, the high-beams work off their own circuit with the driver side H4 harness high beam switched ground as the trigger for the relays. Works like a charm...
I haven't done the alarm fix yet.... maybe later, but for now it's all good. Your write-ups and IceY2k1's stuff helped out a lot! Thanks!
Old Dec 11, 2001 | 03:02 PM
BigDogJonx's Avatar
Thats cool, going all out and stuff. I aint got that kind of patience.
Old Dec 11, 2001 | 03:35 PM
UMD_MaxSE's Avatar
Got Bent?
if you want to change to that setup, I'll help you out with it. It worked great. The relays fit in the relay box right behind the driver headlamp and there was even space to run wires in and out of the box underneath. It is probably overkill, but oh well
Old Dec 11, 2001 | 03:41 PM
BigDogJonx's Avatar
Na na, I am alright with my setup, I aint messing with the HIDs NO MORE! I am done with that "crap" hahaha
hey, what was that guy's name that we helped put on the rear sway bar? I forget his name and his screen name on the org?
Old Dec 11, 2001 | 03:54 PM
UMD_MaxSE's Avatar
Got Bent?
I don't know if he hangs out on the .org .... he does hang out over at the forums on www.5thgenmaximas.com/vbb/ under the user name MaxOnYour6
Old Dec 11, 2001 | 04:26 PM
BigDogJonx's Avatar
You remember his name? real name i mean?
Old Dec 11, 2001 | 05:08 PM
UMD_MaxSE's Avatar
Got Bent?
Donald.... I have his e-mail address... I can mail it to you... just drop me a line....
eckounltd287
51
Aug 19, 2006 07:37 PM
Jief
23
Feb 3, 2002 08:48 PM
