Quick cam questions
Old May 16, 2010 | 11:15 AM
Rhyno02's Avatar
Quick cam questions
I searched and found out that the HR cams are a bit milder than the rev-up cams which is optimal bc my car is a DD. I have the cattman 3" on the way, cattman y pipe waiting to be put in and a ssim + ported upper and ported lower IM, nwp bop and spacers in near future. Would the HR cams be worth the work involved regarding gains? Also would I lose any driveability for daily use?
I just didn't realize how inexpensive these can be had when compared to any other options. Btw, I have the VQ35DE specs with the VQ35HR specs below but, I don't how the differences really translate...
Thanks.
Here's the cam comparison data copied from the "VQ OEM and Aftermarket Cam Data" thread:
Engine: VQ35DE (2)
Model Years: 2002-2005 (Maxima, and a slew of others)
CVTC: Intake
Intake__Lift: 9.5mm
Exhaust_Lift: 9.5mm
Intake__Duration: 238º
Exhaust_Duration: 240º
Intake_Opens: 6º ATDC
Intake_Closes: 64º ABDC
Exhaust_Opens: 52º BBDC
Exhaust_Closes: 8º ATDC
Overlap: 2º
VQ35HR
Engine: VQ35DE
CVTC: Intake and Exhaust
Intake__Lift: 10.5mm
Exhaust_Lift: 10.5mm
Intake__Duration: 248º
Exhaust_Duration: 248º
Intake_Opens: 2º BTDC
Intake_Closes: 66º ABDC
Exhaust_Opens: 68º BBDC
Exhaust_Closes: 0º BTDC
Overlap: 2º
The intake cam has been advanced by 4º and the exhaust cam has been advanced by 2º.
Old May 17, 2010 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
I'd get headers before getting cams.
Old May 17, 2010 | 06:49 AM
Rhyno02's Avatar
Yeah you are right bc a performance cam w/o headers is kinda pi$$ing into the wind. But that's also why I was looking at the HR's since they aren't terribly aggressive but still an upgrade and would work better than stock with the IM setup(Id think anyway) Also, I know it's not an easy job but I'll be replacing the valve cover gasket and plugs while I am in there , so I just figured why not? But I don't wanna do it if only minimal gains are to be had.
Someone has to have done this with a similar setup...I'm curious that's all.
Old May 17, 2010 | 08:39 AM
MoncefA33's Avatar
Cams will make decent power only if you have the software to support it (ie; UTEC, Technosquare, AFC...)
Get headers and a tune first, a cam install goes a lot farther than pulling valve covers off.
Old May 18, 2010 | 12:57 PM
Rhyno02's Avatar
I guess this answers my question. I was hoping that milder cam wouldnt really necessitate a tune, of course I KNOW a tune would be optimal, just hoping I could take the lazy route. lol.
I know a cam requires more than pulling the valve covers, lol. I was just saying if have the IM's off already and the valve covers off, I am there, so why not go farther. Plus I like to do everything at once, I wouldnt want to swap my IM's and then take it all apart again to swap the cams.
Old May 18, 2010 | 01:53 PM
NmexMAX's Avatar
dot dot dot ...
HR cams have CVTC on both I & E cams, so that's obviously another factor in the overall equation. Also, don;t let fully open lift and full durations make the decision for you. You want the spec that has the most area under the curve, i.e. is open for the most amount of time at the highest duration.
IM/VC's are very easy to remove, reinstall. Cams, are a little different, meaning doing the VC's/IM now, and then again later after you're 105% sure what cams you want, wont be that big of deal.
Mar 12, 2020 12:06 AM
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
conansriver
Sep 11, 2015 10:26 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
