ECU Software Update
Old Jun 14, 2010 | 01:09 PM
ZGadson's Avatar
ECU Software Update
I just spoke with my mechanic about my car's inability to shift smoothly between 1st and 2nd even after replacing the valve body for a 2nd time. He suggested I try a software update for the ECU. Apparently there was a mass update covering several Nissan/Infiniti models with numerous fixes - one being transmission timing.
Does anyone know anything else about this? My shop said they could update my ECU for $100 ($25 in labor + $75 for the software from Nissan).
Old Jun 14, 2010 | 01:58 PM
ZGadson's Avatar
30 views and no one knows anything about this?
Old Jun 14, 2010 | 02:19 PM
NmexMAX's Avatar
dot dot dot ...
Seems like a TCM update or replacement might be better. Why did you replace the VB the first time?
Old Jun 14, 2010 | 02:43 PM
ZGadson's Avatar
Transmission was slipping badly. The dealer decided to replace the valve body when it was under warranty - twice. It fixed the slipping temporarily both times, but obviously never actually fixed the problem. (As far as replacing anything, I'm only prepared to throw another $100 at the car at the moment.)
Old Jun 14, 2010 | 03:24 PM
DrunkieTheBear's Avatar
Turbo'd Saab
I agree with Manny or you could honestly just do both. its worth a shot.
Old Jun 14, 2010 | 03:35 PM
ZGadson's Avatar
By TCM... you mean Transmission Control Module, right? (Not familiar with this one. I'll make sure they check this out, too. Thanks!)
Old Jun 14, 2010 | 09:31 PM
SoonerFan's Avatar
Cletus
as mentioned, ECU doesnt have anything to do with shifting...thats the TCM...yes it gets inputs from the ECU, but the TCM is the problem here
it was a problem on 00s...i replaced my TCM with the upgraded one from a 01
Old Jun 14, 2010 | 10:26 PM
Max_5gen's Avatar
Could you elaborate? Was it direct fit, no trip to the dealer? Was it worth the trouble?
Old Jun 14, 2010 | 10:31 PM
SoonerFan's Avatar
Cletus
its plug and play...ordered it from daveb and installed it myself...it isnt cheap though (around $800)
Old Jun 15, 2010 | 06:12 AM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com
Old Jun 16, 2010 | 02:43 AM
Turbo'd Saab
^^^^^^^^that...just find an 01 maxima by searching for interior parts or something, call the place, order it.
IIRC its located under the center console
Old Jun 16, 2010 | 09:35 AM
ZGadson's Avatar
Well, took it to the shop this morning, and they searched their tech sites for an hour looking for the update and ultimately called the dealer - found out that originally, there was a mass update for all Nissans/Infinitis at one point, but in 2007, they decided to seperate updates into Nissan updates OR Infinti updates, and for whatever reason, they no longer offer the update for the I35. My mechanic did try to install the updated Maxima software (which is available, and should have fixed everything), but his computer wouldn't let him due to my car not being a Maxima. The dealer can do it, but wants $350. My shop was charging $100 - which pretty much covered the software and $20 in labor).
Old Jun 16, 2010 | 09:40 AM
NmexMAX's Avatar
dot dot dot ...
That's weird, sounds like Software is all the same ... it's an A33B whichever way you look at it ...
Old Jun 16, 2010 | 05:12 PM
ZGadson's Avatar
That's what my mechanic said. The dealer is beinc stingy with the software and lied their asses off, saying it would only be available from the dealer @ a 300% profit to the dealer, so F it, I'll live with a crappy transmission until I can sell this thing.
Old Jun 16, 2010 | 05:18 PM
Rochester's Avatar
If you can concisely repeat exactly what you want done, then spread your net a little wider. Find a Nissan or Infiniti dealership that will do it for reasonable cost, even if it means taking a little road trip. If you're sure this is the fix, it would be worth the effort. Some shops will aggressively cater to your business, and some will just go by the book. It depends on the management.
Don't give up. Set a goal and make it happen.
Old Jun 16, 2010 | 06:56 PM
the_joow's Avatar
is there any kind of update or aftermarket tuner/tcm that can adjust the shift points on the auto's?... i just hate how evrytime it shifts it drops me below the power band...
please, please, please tell me some good news
Old Jun 17, 2010 | 11:01 PM
Scottwax's Avatar
That's Mr. Detail to you
NWP block plate (search, lots of threads) raises the shift point on automatics. Mine was upshifting at around 6100 rpms before the block plate, immediately after installing it my car was shifting at 6400-6500. Not sure why but others have noticed it too. At $40 for the engraved version, that's the cheapest way other than simply manually shifting your car.
Old Jun 18, 2010 | 06:10 AM
NmexMAX's Avatar
dot dot dot ...
I need to do a little assessment of this. I have an SSIM, and m,ine still shifts where it's supposed to. But I still have a functioning solenoid/vacuum/etc.
I'm thinking the higher shift points might be related to that end of it, since mine is still the way it was before I added the SSIM. So, perhaps this weekend I my in fact set-up my solenoid etc. to mimic that as if I had said block plate and see what happens.
Hell, I should spend the time purchasing and installing the Suprastick Lazy/cheap me.
Old Jun 18, 2010 | 11:10 AM
KiNgJaMEs's Avatar
SSV4 is what I use
Old Jun 18, 2010 | 12:10 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by KiNgJaMEs
SSV4 is what I use
Old Jun 19, 2010 | 06:56 PM
the_joow's Avatar
i usually stretch it out to about 6800 when i do it "manually"... i wanted a stick but my wife refuses to learn how to drive one...
Old Jun 19, 2010 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
Unless you have a reflash, your tach is lying to you.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
