power on top
Old Jun 15, 2010 | 03:14 PM
tothemax2003's Avatar
power on top
i have been told that our maximas are horrible on top end , why is that and is there anything that could be done to fix the problem
Old Jun 15, 2010 | 03:30 PM
5 ltr. beater's Avatar
this is news to me , i have a bone stock DE-K and she pulls pretty good up top. can only imagine a VQ35 would pull only harder.
Old Jun 15, 2010 | 03:37 PM
NmexMAX's Avatar
dot dot dot ...
Do you have dynos to prove this?
Key words you used and need to describe
1.) Horrible
2.) Problem
Explain what you mean by horrible, and how is it a problem, if there's nothing wrong and that's the way it was designed?
The A32 USIM sure showed that, but it (power curve) doesn't get much prettier than the DEK, VQ35 isn't as bad as the A32, but we've found ways to accommodate this at the loss of low end.
Old Jun 15, 2010 | 03:42 PM
i read a thread where an acura tl beat a 2002 maxima really bad on top, and wanted to know if thats the norm and what can we do to better the car on topend.
Old Jun 15, 2010 | 04:29 PM
2slow's Avatar
It's true, you're only hope against the almighty TL:
or:
Old Jun 15, 2010 | 08:43 PM
Rods03Max619's Avatar
or:
Didn't know how mighty they were!!
Old Jun 15, 2010 | 08:46 PM
jasonmax's Avatar
maxima top-end is actually pretty good
my rotary has rubbish low-end
you cant get both with NA engine unless you turbo or supercharge.
Old Jun 15, 2010 | 08:50 PM
NmexMAX's Avatar
dot dot dot ...
If you turbo or sc then it wouldn't be na anymore
Old Jun 15, 2010 | 09:38 PM
Z-Powered's Avatar
Cheapest way: VIAS valve block off plate.
Best way: SSIM (basically gutting the intake manifold)
Old Jun 16, 2010 | 03:20 AM
Roca Fella Bryan's Avatar
Get a six speed manual Nissan Maxima or a 5speed auto 6th gen. I used to own an 2002 Acura TL Type-S but sold it because the transmission went to hell on me. It was slower than my current 02 6-speed in every respect from the quarter mile to higher speeds with the same mods (intake).
Old Jun 16, 2010 | 03:31 AM
SoonerFan's Avatar
Cletus
i had no problem...yes it tapers off up top...but you are only there for a few seconds before you shift...6MT helps a lot
Old Jun 16, 2010 | 12:48 PM
CraigSE's Avatar
I thought the top end was pretty good.
Pull is certainly best around 4500-5500, but even up to almost 7k, it still pulls.
Old Jun 16, 2010 | 08:25 PM
ABlackSER's Avatar
My SE-R is a beast at low and top end
Old Jun 16, 2010 | 08:46 PM
fpromax02's Avatar
I'm not sure where u got yr info from....but my 02 has kno prob up top...and as far as TL's go...I've never had to stress that..
Old Jun 16, 2010 | 08:57 PM
NmexMAX's Avatar
dot dot dot ...
My peak airflow is 60 percent and at 7100 it's at 59 percent.
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
Sep 27, 2015 08:37 AM
zmcneely13
Sep 26, 2015 02:26 PM
