Looking for some help.. Starting Issue!
Old Jun 22, 2010 | 12:50 PM
95Maxi's Avatar
Ok im new to the 5th gen world .. I have always owned 4th gens .. I know alot of things are the same but want to do some double checking on this starting issue that I have now .. and today I got stuck ,
Ok so I replaced the battery and altenator recently cause it was needed ... but prior to changing that out I thought I was getting starting problems due to the power issue I was having with the battery and altentor and battery .. But no difference ill start it and it will try to grab hesitate and then grab but I would have to keep the key turned for that extra second !! then it would start and sometimes id get no problem .. well no all my power is fine i tried starting it got the hesitation then nothing i can hear the starter wind up (very soft sound and nothing )and i hear that click sound from the relay .. No other clicking sounds or grinding sounds nothing ...
Is this my stater bad ? the radio everything is perfect !!! no loss of power .. I tried jumping it but that didn't work either ..
I would appreciate as much help as I could get !
Old Jun 22, 2010 | 01:06 PM
BIG C's Avatar
check to make sure that your crank pulley isnt bent. i changed my crank pulley and the car started up perfectly fine. i had the same starting issues it sounds like your having. hope this helps
Old Jun 22, 2010 | 01:34 PM
95Maxi's Avatar
Im going to check it tonight !!! Thanks, I hope its not that!
Old Jun 23, 2010 | 06:43 AM
95Maxi's Avatar
Ok so I checked to see if the crank pulley was bent and that is a negative .. I replaced the crank position sensor thinking MAYBE !! but nothing !! .. It doesnt even try to start NO CRANK AT ALL! I hear the starter doing something i banged on it last night and at one point I almost had something !! Whats up any other ideas .. I mean its always givin me a problem starting , But drives perfect!
Thanks ahead for any info!
Old Jun 23, 2010 | 07:04 AM
OhOhMax's Avatar
Change your starter out, I did it in the rain at the auto parts store, it doesn't take very long at all.
Old Jun 23, 2010 | 07:42 AM
95Maxi's Avatar
Sounds like the best idea yet !!
Old Jun 23, 2010 | 08:33 AM
Froggmann's Avatar
Also check your groundpoint going from the engine to the front head. If that isn't tight or is corroded your starter won't get enough juice to turn the engine over. Also make sure your battery terminals aren't loose or corroded.
Old Jun 23, 2010 | 09:24 AM
95Maxi's Avatar
where is that located exactly ?
"groundpoint going from the engine to the front head."
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
