Fuel door misalignment
Old Jul 4, 2010 | 08:30 PM
2 GO B4's Avatar
So I went to pump gas today and didn't notice anything different about opening or closing the fuel door....but as I drove off...I look in the side mirror and notice that the fuel door is not sitting flush with the body of the car....I thought that I just didn't close it but when I checked it....it was closed but sticking out past the body of the car about a 5th of an inch or so( the side of the fuel door pointing towards the front of the car).....WTF???...so after messing around and oiling the hinge and taking the door off.....the shiznit won't sit flush with the body.....
Has this happened to any of you guys and how did you fix it.....I am a bit annoyed because I dented the fuel door a bit as I was messing with it and trying to force it flush with the car body......
As always guys and gals....any input would be wonderful....THANKS!
PS....I tried a search before opening this thread but nothing popped up...
Old Jul 4, 2010 | 08:36 PM
Andypot1985's Avatar
omg yes it has happened and is still annoying me to this day because i have the dents too! I have been looking forever for a fuel door for my car and come up with no results. I go to the junkyard and the fuel doors on the cars there are dented too.
Old Jul 4, 2010 | 08:39 PM
CustomLowz's Avatar
I had that happen with my car. No matter how much tweaking with it, the door would NEVER sit right. I just replaced the door and fixed the problem.
Old Jul 4, 2010 | 08:40 PM
2 GO B4's Avatar
The thing is that nothing feels loose in the door or the hinge and I am sure that I didn't bend anything before this happened.....thus I am baffled as to what shifted to cause this weird shiznit to happen
Old Jul 4, 2010 | 08:41 PM
2 GO B4's Avatar
What did the new door end up costing you...and did it come painted or did you have to deal with that too...
Old Jul 4, 2010 | 09:38 PM
CustomLowz's Avatar
I bought it from another member, and My brother owns a body shop, so he just painted it for me when he painted my front and rear lip.
Old Jul 5, 2010 | 06:34 AM
2 GO B4's Avatar
I think I know what is wrong with the fuel door now....there is some piece of metal that is clipped to the inside of the fuel door (near the back end) that is supposed to slide along the inside fixed portion of the fuel door bracket and then snap over its edge (this will allow it to sit flush with the body of the car).....well for some odd reason it stopped sliding all of the way and does not snap over the edge.....thus the fixed portion of the fuel door bracket is pushing the front end of the fuel door forward and out and this is what is causing it to not sit flush with the body.......I tried bending that bracket back and forth but it either results in the fuel door not opening or opening fine but STILL does not sit flush with the body of the car.... WTF WTF WTF.... ....guess I'm gonna have to buy a new door then!
Old Jul 5, 2010 | 07:47 AM
Relic's Avatar
I thought I was the only one with this problem.
Old Jul 6, 2010 | 06:40 PM
2 GO B4's Avatar
nope....i guess it is more common of a problem than we think....
Old Jul 6, 2010 | 07:17 PM
yamahaman88's Avatar
yeah i began to notice this problem as well. then one day the hinge broke and i couldnt open the door .thank god i have a long wing span because i used to have to open my fuel door while i held the button down inside the driver door. about a month or so later i finally found a decent junk yard door/hinge and replaced it...i recommend replacing the entire assembly before these embarrassing gas fill ups happen to you
Old Jul 7, 2010 | 09:52 AM
mandyfig's Avatar
Same here the freeking fuel door does not sit flush. I just do not look at it.
Old Jul 7, 2010 | 12:32 PM
Stalldaworld's Avatar
Same here. Mines dented doesnt sit right bc its bent and the assembly to close it is broken.
Old Jul 7, 2010 | 06:28 PM
2 GO B4's Avatar
its funny.....my old...do i dare say it....HONDA....never had that problem and I drove that shiznit forever.....I mean...COME ON NISSAN.....the freakin fuel door.....for gods sake.....the car should fall apart before something like the fuel door hinge goes bad....WTF!
Old Jul 8, 2010 | 07:28 AM
mandyfig's Avatar
Just one of those that did not get the attention. You'll get used to it.
Old Aug 7, 2010 | 09:57 AM
Rods03Max619's Avatar
Me never had any problem with my fuel door always looks good to me but should check it just to make sure everything is flush!!
Old Aug 7, 2010 | 10:13 AM
MatMax01's Avatar
My fuel door is bent also. My wife was driving the car and SAID SHE DID NOTHING WRONG. I thought it she had a blonde moment but i see alot of you have the same problem. The more I tried to fix it the more it god worse. I have a 94 accord and the fuel door is perfect.
Old Aug 7, 2010 | 10:35 AM
BLUEMAX01SE's Avatar
+1 Had same problem with this rinky dink fuel door for about 5+ years now. Tried to mess with it and ended up bending a bit. Finally just got to the point where I just don't even pay attention to it! Seems like the hinge gets warped or something!
Old Aug 7, 2010 | 11:07 AM
sascuderi's Avatar
Just check my 2000 I30 and it seems fine. When I close it the latch slips over the plastic accuator prong keeping it flush. isn't the Max set up that way too?
Old Aug 7, 2010 | 11:16 AM
2000_MAXIMA_KING's Avatar
I keep finding mine open anyone have this problem it just recently started happening.
Old Aug 9, 2010 | 06:59 AM
ColdRain's Avatar
I had same problem here. Once, gas station attendant in Jersey felt it was open even tho it was closed and decided to hit it hard, and i think he bent hinges. So for few months my fuel door was completely misaligned and needed some roughing up to close every time it was used. On top of that hinges screws were so rusted that I couldn't even take off fuel door. Now, after few months in winter my dad decided to hit it hard when it wouldn't close, and completely came loose and prob. lost the door on highway. Now, I'm riding around with no fuel door, but Locked fuel cap. Embarrassing.
Old Aug 9, 2010 | 09:13 AM
guezroks's Avatar
LOL. i guess ill leave my gas door in peace now.
Old Aug 9, 2010 | 03:58 PM
Superman_03's Avatar
dang.....same problem herre.....guy hit n ran me on the driver corner and realligned the fuel door..gota wait to fix it and hopefully bodyshop can fix it
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
