Still having exhast problem
Old Dec 13, 2001 | 10:31 PM
ara662's Avatar
I unpluged the battery for an hour, survice light still on. What should I do?
Old Dec 13, 2001 | 11:57 PM
RBa's Avatar
RBa
Re: Still having exhast problem
Replace the o2 sensor....
Old Dec 14, 2001 | 12:18 AM
emax02's Avatar
Re: Re: Still having exhast problem
Which one ? There is atleast 3{2K fed spec} o2 sensors on his/her max.
ara662, what makes you think it has something to do with the exhaust? There are atleast 25 different sensors that can set off a MIL code. Do a diagnostic, get the # and find out what your problem is. BTW, unplugging your battery for only 1 hour may not do the trick, it may take more time.
Old Dec 14, 2001 | 01:44 AM
RBa's Avatar
RBa
Re: Re: Re: Still having exhast problem
I thought since he mentioned exhaust, the problem would lie with the o2 sensors...
Old Dec 14, 2001 | 03:59 AM
UMD_MaxSE's Avatar
Got Bent?
first of all, what kind of emissions do you have? Is it a 2k1 or is it 2k? I remember the other thread you posted about getting the wrong y-pipe, so I am guessing you have a cali spec since you also mentioned that you removed the front pre-cat. Did you put everything back to stock? If so, and the light is still on, then you may have a bad O2 sensor. I had a bad O2 sensor on bank 1 that caused my CEL to go on... went to the dealer and got it fixed...
Old Dec 14, 2001 | 06:03 AM
Blackgums100's Avatar
UMD
Maybe he should just leave it as is until he gets the correct Y from Cattman. He can't do any harm to his engine, can he?
Old Dec 14, 2001 | 06:09 AM
UMD_MaxSE's Avatar
Got Bent?
Re: UMD
nothing serious probably....
Old Dec 14, 2001 | 08:39 AM
ara662's Avatar
I have a 2001 cali spec. YEs And I took the front pre cat out with a hammer and a screw driver .Am I screwed now???
Old Dec 14, 2001 | 09:12 AM
UMD_MaxSE's Avatar
Got Bent?
you gutted the thing?
Old Dec 14, 2001 | 09:17 AM
ara662's Avatar
Thats What happens when you give a hammer and screw driver to a RUSSIAN . So what do you think I should do???
Old Dec 14, 2001 | 09:22 AM
Relax
I am going to leave this to one of the more knowledgable org members but I am 99% sure running your car as is until you get the correct Y-pipe should be fine.
Old Dec 14, 2001 | 09:29 AM
UMD_MaxSE's Avatar
Got Bent?
you have a couple of options:
Bring it back to stock and bolt up everything just like you haven't touched it and take it to the dealer. Maybe the will give you a new front pre-cat.... don't tell them you touched it
OR
Remove the front pre cat and front exhaust manifold entirely. Buy a fed spec front manfiold from any 95-00 maxima. Bolt that up to the engine and then use the fed spec y-pipe. You will have to relocate the O2 sensors the were supposed to go behind the front pre-cat to behind the main cat by drilling a hole in the b-pipe. Reset ECU, and you are done
Old Dec 14, 2001 | 09:43 AM
ara662's Avatar
IS it ok to drive my car like that??? How much is a new pre cat?
Old Dec 14, 2001 | 09:52 AM
UMD
Your info is good, I have seen you have posted quite a bit regarding Y-pipes. I plan on ordering the Cattman, don't worry I will make sure I get the right one. Did you do the install yourself? I have seen the instructions, but without a lift I would rather take it to a shop. Could you recommend one? I live in Northern VA, if not no bigee I'm sure I could find a local shop. Also, about what will I pay to have it installed? Thanks in advance for any info.
Old Dec 14, 2001 | 10:08 AM
ara662's Avatar
Re: UMD
I installed the y-pipe my self. It was a real B!tch only because I had to put the stock Y back. When I get the right y-pipe I'll take it to the shoop. I should be around $50
UMD_MaxSE's Avatar
Got Bent?
ara622: The downstream O2 sensor is only checking the presence of the pre-cat... not adjusting A/F ratio... so you should be ok as long as the up stream front O2 sensor is ok. A new pre-cat is probably expensive... but you can get a fed spec manifold from a junkyard or other parts site pretty cheap....
Blackgums: The install is not too tough as long as you have floor jack and jack stands... it takes time and can be frustrating getting the old pipe off. There are a few shops that will do the install. Rayco in silver spring (intersection of Georgia Ave and 450), and Altered Atmosphere (www.alteredatmosphere.com) in Gaithersburg both will do the install for less than $100....
Old Dec 14, 2001 | 11:43 AM
ara662's Avatar
I just cheked with a dealer pre cat is $785.
Old Dec 14, 2001 | 11:59 AM
UMD_MaxSE's Avatar
Got Bent?
you can get a fed spec manifold cheap...
Old Dec 14, 2001 | 12:46 PM
ara662's Avatar
WHere would be a good place to get one cheap
Old Dec 14, 2001 | 12:50 PM
UMD_MaxSE's Avatar
Got Bent?
junkyards? internet part sites
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
