PLEASE HELP, CLUNKING NOISE OVER BUMPS!
Old 08-04-2010, 11:25 PM
OutMaxxed's Avatar
Hey Everyone,
I am hoping someone can help me here. My front passenger end is making a clunking noise over bumps. I am lowered on BC Racing Coilovers. The car just sits on top of the stock 225/50/17 tires if your wondering how low it is. I wouldnt say it is slammed. Maybe a tad lower than S-techs??
I changed out both front axles in June. I JUST changed the entire front passenger control arm. It came with new balljoints, bushings, etc. I also changed the outer tie rod and the sway bar links. It took me dam near 6 hrs just for one side because it is so dam rusted down there. It seems like the longer I drive it, is when the noise starts coming. I figured it was the ball joint grease warming up and as it did, the joint wouldnt be as well lubricated and thus the noise. But its STILL doing it. It sounds SLIGHTLY duller than before but its still there.
Can it be that im TOO LOW? I mean im not nearly as slammed as some of the people on here. Could it be the "Inner Tie Rod"? Wheel Bearing? Could it be the Coilover? I dont think its the axle again. I am leaning towards the inner tie, what does that sound like? I just invested so much time into fixing this and I still have a problem. It would be great if you guys can give your insight. Thanks
Regards,
Kelvin
OutMaxxed is offline
Old 08-04-2010, 11:43 PM
roggeezy's Avatar
Check the passenger side motor mount
roggeezy is offline
Old 08-04-2010, 11:45 PM
Gram Lights addict
QT1 5MT AE's Avatar
tire rub? blown shocks?
QT1 5MT AE is offline
Old 08-04-2010, 11:46 PM
OutMaxxed's Avatar
Just looked at the mount. It looks ok i guess? Its not leaking any grease or anything? what do u look for in bad motor mounts? and I dont think its tire rub and the coilovers are 3.5months old.
Thanks for the input, keep em coming please!
Old 08-04-2010, 11:57 PM
Gemner's Avatar
i can almost guarantee you its that mount. It is notorious for making that sound even when the mount looks fine. Is there anybody nearby that you know who has an NWP torque mount? If you put one on and lock it down, if the clunking stops then it is the fault of your mount
if it was tire rub it wouldnt be a clunking noise
Gemner is offline
Old 08-05-2010, 12:16 AM
OutMaxxed's Avatar
No I dont know anyone with one, is the motor mount your talking about the one on the left side of the engine when you pop the hood?
Old 08-05-2010, 03:55 AM
Don't you know who I am?
Rydicule's Avatar
Not to be an ***, but my car clunked all the time. Everytime I fixed one, another one would show up.
I had taken it to the mechanic 3 times and he would verify that it was clunking, but could never figure out what it was. He just assured me the suspension was in good working order
Rydicule is offline
Old 08-05-2010, 05:26 AM
mandyfig's Avatar
Check out posts on ebay engine mounts. Lots of pics and ways to check your mount if busted.
mandyfig is offline
Old 08-05-2010, 05:48 AM
CraigSE's Avatar
Fixed an annoying and elusive clunk on my dads 2000 with some new sway bar bushings (where they attach to the frame) the sway bar was moving up and down kissing something near/on the firewall or back of the engine.
New bushings, no noise.
CraigSE is offline
Old 08-05-2010, 02:34 PM
roggeezy's Avatar
I had the same problem as you where I had a clunking sound which sounded like a blown strut. My mount looked perfectly fine from the outside but that turned out to be problem. I recently bought BC coilovers and I installed ES LCA bushings and the sound still existed. I bit the bullet and bought a mount for $60 bucks and put it in myself and the sound went away.
roggeezy is offline
Old 08-05-2010, 02:50 PM
spock's Avatar
Same here. Mount looked fine. Replaced it and no more clunk.
spock is offline
Old 08-05-2010, 02:51 PM
Nexus67's Avatar
Other than a mount, I would definitely check (and I get knocked for this sometimes) your hood latch.
Noticed my hood slightly 'jumping'. Saw it was rusted so I WD40ed it, and wrapped the hook (that connects to the latch) with electrical tape. I don't know it worked for me, couldn't hurt to check I suppose...
Nexus67 is offline
Old 08-24-2010, 01:56 PM
max2000ima's Avatar
The same thing happened in my 3rd generation maxima. Fixed the mounts and no more clunk. Since you have tightened your suspension you will notice a few more noises.
max2000ima is offline
Old 08-24-2010, 03:36 PM
Curb Rash Repair 100 a wheel
Maxima112's Avatar
its the mount if you wanted to check it here's what i did: put my left hand on the bolt area of the mount then with my right (or a friend could help here) push down multiple times on the top of the manifold (for 3.0 max I pushed on the black part of the engine that doesn't get hot) to simulate the car going over bumps. if you feel a thump or clunk then 100% its your mounts.
Maxima112 is offline
Old 08-24-2010, 03:40 PM
spock's Avatar
Why not adjust the latch and bump stops - do it correctly? Electrical tape?
spock is offline
Old 08-25-2010, 04:21 AM
yogi's Avatar
Thats what i thought - mounts should be making some noise when starting the car - if bad, but there is silence in mine.
I took a look at the mount yesterday and it looks fine, I tried to push down on the manifold just to verify that mount is making noise but to no avail - silence again.
Then i pushed on the driver side fender couple time - and boom - clunking again.
It seems that the noises are coming from somewhere around the firewall, very close to the wheel.
The biggest mystery for me is that when i changed my suspension, the noises went away for about 4 days...hence why i thought that the issue might be with ball joints, tie rods or sway bar bushings...
Correct me if i`m wrong, but there are 4 mounts in our cars, but is there one by the firewall?
Anyway i will be taking "closer" look at it this weekend.
yogi is offline
Old 08-25-2010, 04:39 AM
vastmax's Avatar
yeah...the rear mount, i'd say this is the most common mount to fail. Have you replaced sway bar end links and bushings?
vastmax is offline
Old 08-25-2010, 04:58 AM
yogi's Avatar
Well, no but
I was going to put an order to jegs.com but noticed that there are two sets
Energy Suspension #355-7-3118R going for 69.99
Energy Suspension #355-7-3118G going for 49.99
Somebody knows what is the difference btw those sets?
Plus i`m thinking about adding the mount to the order, but just want to be sure
yogi is offline
Old 08-25-2010, 09:54 AM
slo-ryde's Avatar
Inner Tie Rod?
Originally Posted by OutMaxxed
Hey Everyone,
Regards,
Kelvin
Yep, my 02 GLE was making a knock/clunk when driving over speed bumps too. It was the inner tie rod. It's not that hard to replace but you'll need a special tool to get it off. I picked up one at Harbor Freight for about $35 with a coupon. You could probably rent one too.
slo-ryde is offline
Old 08-25-2010, 10:01 AM
vastmax's Avatar
Originally Posted by yogi
Well, no but
please search man....ones red, ones black. these are inserts, not to whole mount.
vastmax is offline
06-06-2017 02:01 PM
D Mason
06-21-2016 04:43 AM
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
Quick Reply: PLEASE HELP, CLUNKING NOISE OVER BUMPS!
