Air conditioner temp is only 54 degrees
Old Aug 8, 2010 | 04:06 PM
02_Maxima_6sd's Avatar
My son's 02 maxima does not get cold enough when I put the manual setting to 4.(4 is the max and I do have it set to recirculate) The air temp will stay at a constant 54 degrees while I am driving it. If I lower the **** to level 2, the temp will go down to 44 degrees.
Do you guys think the max just need freon?
I don't believe I have a leak since it will hit 44 degrees...
Old Aug 8, 2010 | 04:11 PM
SteveB123's Avatar
If you need freon, you have a leak.
Old Aug 8, 2010 | 04:21 PM
Specd_out's Avatar
Thats normal. almost every a/c i have ever used will have a higher temp on the highest fan setting. The number dosent relate to temp the blue and red slider does. so the higher the fan speed the less time the air has to be chilled before its sent into the cabin.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
