No fire... NEED HELP
Hi guys,
I just swaped my motor in my 03 for the same thing because the last one blows out. Now, everything is replug, change the flywheel for a fidanza with a new clutch (exedy stage 1), change the cover valve for 04 cover, change the spark plug.... Now, I try to start the car and it wont start. I have a signal in the coilpack but no fire... I recheck everything to make sure that I didnt forgot anything but it looks fine. I really hope that someone will have an idea for my problem. I have read some thread that said that it can be a ground but ... thx everyone.
Max
Max
Thx guy, I found the problem. I have a P0335 code. I read that on the flywheel there's 2 alignement hole. It is write front and rear. I put it on the wrong alignement hole. So now, I have to drop the motor again and the tranny and ......... ***** !
I just want to make sure if I have torque the clutchand the flywheel properly. I took the oem torque spec for the flywheel. It says about 32. And is there any recall on the cps because now I dont want to realign my flywheel and still have the P0335 code. thx in advance
