Trunk Sub Floor
Old Aug 30, 2010 | 08:47 AM
tedo007's Avatar
faster than you think
Trunk Sub Floor
Where can I find the wood piece and mat from? Mine got all the water on it and broke and mat stinks!.
Old Aug 30, 2010 | 08:58 AM
ghostrider17's Avatar
djfrestyl sells the replacement/upgraded wood -- which I highly recommend over the OEM fiberboard crapola!!
Old Aug 30, 2010 | 09:43 AM
qstick777's Avatar
Here's the really nice version:
http://forums.maxima.org/general-max...tion-sale.html
Had a similar problem with my old Altima - except it was a couple of gallons of antifreeze and oil!
I just used the old one as a template and cut out a sheet of plywood to lay down - didn't worry about putting carpet on it. You should be able to pick up automotive carpet for about $20 for a good sized roll.
$25 for plywood, $20 for carpet and a little time. Of course, that only covers the spare tire, not the rest of the trunk.
As far as the mat replacement, haven't seen any custom fit that are cheaper than $50-60, and that was for vinyl. $100+ for carpet.
Have you tried hitting the mat with some cleaner and letting it air dry for a couple of days?
Old Aug 30, 2010 | 10:23 AM
zero2sixtyZ's Avatar
You embarrass me.
+1 for djfrestyl's covers. Perfect fit and so much better than the cheap cardboard crap.
Old Aug 30, 2010 | 01:15 PM
SoonerFan's Avatar
Cletus
you can make your own out of plywood
Old Aug 30, 2010 | 07:05 PM
Nexus67's Avatar
Originally Posted by qstick777
I'm currently using djfrest's trunk board b/c my OEM got wet and crunched like the OP's. OP, you can't go wrong w/ djfrest's setup, but as others mentioned you can indeed build one of your own. (Me personally, I a lot of work in my Talon w/ no will leftover to do what I want to the Max)
Old Aug 31, 2010 | 02:31 AM
tedo007's Avatar
Thank you guys for the information. I think I'm going to go with that.
Old Aug 31, 2010 | 06:15 AM
NmexMAX's Avatar
dot dot dot ...
Or Dave B can get you one for cheap (36$), but you will need to apply the carpet on your own.
Old Aug 31, 2010 | 08:40 AM
mandyfig's Avatar
The salvage or junkyard will have some.
Old Aug 31, 2010 | 10:08 AM
Nexus67's Avatar
Just an FYI, djrest's version is much stronger than OEM and is $40 w/o the carpet.
Old Aug 31, 2010 | 11:51 AM
SoonerFan's Avatar
Cletus
$40....or a few dollars for some scrap plywood...cut your own
can hold the weight of a wife removed strut nuts
Old Nov 11, 2010 | 01:36 PM
djfrestyl's Avatar
Suspension Yoda
I seem to have found this thread
For those DIY'ers out there, I hope you reconsider, help a fellow org member out!
REDinLV
Aug 15, 2024 12:30 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
