nwp spacers+vias block-off plate=problem
ok guys i installed my nwp spacers on my 02 max and i did the block off plate while i was at it. after i got done i did the the the throttle relearn procedures, started the car and the car runs real rough for about three seconds and then it dies. i tried giving it gas and it acts like it don't won't to take the gas and then it revs real high. also as i try to give it gas it gives of a small backfire through the air box. i cleaned the throttle body too if that may help with anything. i didn't spray it with anything just took a rag and wiped it out. i double checked to make sure everything was hooked up. what could possibly be wrong?
Hmm. make sure the maf is connected, and re do the learning procedure. If that does not work I would disassemble and make sure everything is sealed properly again. something is not sealed correctly.
^^ this and see if its on the right way...also try to take some extra sealant and go around all the spacers on the manifold
Is there a right and a wrong way to put the TB spacer on?
http://forums.maxima.org/5th-generat...ly-yes-no.html
Same **** happened to me car turn off once but turned it back on and kept giving it gas the car sounded like **** but stayed on tried that procedure like 5 times didn't work went driving a little bit and the idle went a little smoother bvut still rough and then the next day was still there but minor the 2nd day completely gone think the idle is getting used to the new flow and a couple of more days past and the CEL went off by itself. So dont panic everything should be cool just got to give it a little time I was pm'ing everybody about it when it happened to me but good luck!!
Vacuum leak.
u have a vac leak somewhere, take everything off and do it again. make sure everything is torqued down and all hose connected. Just one vac hose left unconnected and the car will start but not run.
my bet is u left a vac hose disconnected. Happens to all of us that take these things part.
if u put RTV on the spacer just check the torque on the on the IM. It will be a ***** to get all that RTV off. i dont even use RTV on my IM as long as its torqued ur good.
but check those hoses on the back of the IM, I pull my IM all the time and sometimes i forget to put those hoses back on and i try to start the car it runs for a little its really rough then just dies.
If you start the car and keep giving it gas until it warms up, it should stay on at normal operating temp. if you wanna try to locate the leak. But Im almost positive that its coming from where the upper IM meets the lower IM.
You need to take the IM back off and clean off all of the silicone really good. Make sure you have a clean mating surface. When you re-apply the silicone and apply it evenly.
with the spacers you dont need to worry about getting all the RTV off. Just get it off the aluminum surfaces and youre good to go. Which is usually easy to do since most of it stays stuck to the spacers
u'll be str8 without it its just extra security.
i had to us alittle on my LIM because i did porting and the dremel jumped hit the mounting surface, but generally on my Intake and UIM i dont use it because i just take it a part so much.
plus u can easily damage teh spacer trying to get it all off, just get it generally clean.
Ok guys i got it figured out thanks to all your help. i got the torque wrench out and started to give a couple turns on the upper intake and heard a pop. And i thought "yea i really screwed it up this time" so i went to start her up after i heard the noise and she fired right up and had no problems. so i went back to the stud on the passenger side that i was tightening and gave it a half of turn to snug her up and that was it. I knew when i was tightening the nut yesterday it felt funny.LOL.now just gotta get her to take the idle relearn n i'll be done. shes idling around 850-900 i think its suppose to be lower than that. but thanks for the help guys. glad i didn't take it back apart.
-ReLLiK-
09-08-2015 12:02 PM
