HID problem
Old Sep 4, 2010 | 06:12 PM
Spence's Avatar
HID problem
So I bought a set of used headlights with HID's in them from an org member here, and they've lasted me a couple months and worked great.
Until recently, when I started going over bumps they started the flicker off then back on. Then the problem got worse by when I hit a bump they would stay off. I fixed the problem by taping a wire down. I've hit one last bump and now they will not turn on at all. But if I put on the high beams both of them will work fine, but I no longer have the HID part available, just halogen high beams.
I checked to make sure all the connections were still strong, which they are, and everything seems to be in working order. Not sure if the fuse is blown, I removed it to look at it and it seems fine.
Just wondering if anyone knew anything about this HID related problem, and any help would be appreciated.
Thanks-Spence'
Old Sep 4, 2010 | 09:18 PM
luvlexus101's Avatar
Is it only one side or both sides?
Old Sep 5, 2010 | 12:05 AM
Nismo215's Avatar
i had somewhat the same problem before..and i just replaced both of the bulbs and now, problem solved GL
Old Sep 5, 2010 | 05:16 AM
Progress's Avatar
It's business time.
I would replace bulbs as a last resort. Test the ballast(s) first.
Old Sep 5, 2010 | 11:42 AM
MoncefA33's Avatar
for ballasts.
Old Sep 5, 2010 | 03:32 PM
Spence's Avatar
It is both sides that go out. But I would imagine that if the bulbs were blown, then the lights wouldn't turn on with the high beam. I could be wrong.
How about to I go about testing the ballasts?
Old Sep 5, 2010 | 08:22 PM
KBCobra's Avatar
Try them on another car with HID's. When you turn the lights on, do they buzz on or do they make no noise at all?
Old Sep 5, 2010 | 10:16 PM
Spence's Avatar
They do not make any noise at all. I find it odd though. I've looked up a few things as to what it could be, and it looks like I'll be trying them once it's morning. Hopefully it works
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
