Timing Chain
Old Sep 8, 2010 | 07:25 AM
rbourne's Avatar
Timing Chain
My mechanic changed my timing chain. A bolt holding the larger of the 3 sprockets on top keeps loosening and the chain slaps around. Any ideas as to the cause is appreciated.
Thanks,
Bob
Old Sep 8, 2010 | 07:30 AM
ghostrider17's Avatar
Lack of Loctite?!
Old Sep 8, 2010 | 07:41 AM
apom's Avatar
Just take it back to your mechanic. He should fix it for free
Old Sep 8, 2010 | 08:10 AM
rbourne's Avatar
Timing chain
Thanks for the immediate response, but I'm looking for a more expert assessment of the problem rather than use Lockbite or take it back to the mechanic. Anyone else out there that can offer their view?
Tks,
Bob
Old Sep 8, 2010 | 08:18 AM
phatboislim's Avatar
some of those bolts probably should have had loctite on it upon reinstall and torqued.. or some sort of thread locker. i'm curious as to why you had it changed..
Old Sep 8, 2010 | 08:41 AM
rroderiques77's Avatar
Demodded and Forgotten
Tks,
Bob
I am confused, when you had your "mechanic" replace your timing chain, did you not think he was "expert" enough? The bottom line is that the bolt needs to have lock tite and be torqued to specs. Hopefully it is not stripped. Did he replace the sprockets with the install?
Old Sep 8, 2010 | 11:01 AM
SoonerFan's Avatar
Cletus
dont know why you felt the need to change it...it isnt a wear item like a timing belt...
how "expert" do we need to be...bolt is loose...tighten it...
and you should find someone else to work on your car
Old Sep 8, 2010 | 01:09 PM
rbourne's Avatar
The work was performed because of ba guides. The kit I purchased had everything, hences, why my mechanic changed the chain and sprokets as well. Although my mechanic did not use a torque wrench, I know it was tightened as tight as humanly possible. What exactly is Loctite? How does it work? Will it work on a part that has so much pressure? All help is appreciated.
Bob
Old Sep 8, 2010 | 01:15 PM
NmexMAX's Avatar
dot dot dot ...
A tight as humanly possible isn't good enough, in fact it might be too "good" from your invalid apparent analogy of tighter is better.
If he used the FSM as a reference, which he better if he's doing the job correctly, there is a specific tightening pattern and specific torque to go along with that. There are reasons for this logic. (load on either end of the engine sprocket plane should be equally distributed, and if that condition is not met, there maybe undue load on either end of this 'face/plane', etc. which in turn may result in the loosening of a certain bolt/bolts/assembly, on the opposing end)
If that was not followed, he better do it again, and replace any parts if necessary at his own cost.
By the way, what year is your car?
Old Sep 8, 2010 | 01:28 PM
thats scary to know that your 'mechanic' didnt use a torque wrench...i dont do certain things on my car because i dont own one and i know my mechanic does great work. you need to find another mechanic...sorry
Old Sep 8, 2010 | 01:39 PM
rbourne's Avatar
The car is a 97 Altima. Can anyone tell what the torque should be on the sproket?
Old Sep 8, 2010 | 01:43 PM
NmexMAX's Avatar
dot dot dot ...
Jeebus cripes mang.
It wasn't until 2002 when Maxima and Altima started sharing engines. And that ended in 2007, then reoccurred in 2009, but not anything 5th gen related would help you out unless you have a VQ swapped 97 Sentra.
Old Sep 8, 2010 | 02:35 PM
VQP0WER's Avatar
Bob
http://www.lmgtfy.com/?q=Loctite
Old Sep 8, 2010 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
Is this a KA24DE?
Old Sep 8, 2010 | 02:51 PM
Amave's Avatar
Originally Posted by NmexMAX
Is this a KA24DE?
if it's a an Altima then yep i'd bet its a KA engine in there...
and car manufacturers have torque specs for a reason...i'd trust the engineers know what they are doing...
and every mechanic should have a torque wrench for sensitive bolts ( i.e sprockets, oil pan bolts, etc. )
Old Sep 8, 2010 | 03:12 PM
spock's Avatar
Every mechanic should have several torque wrenches that very in range and size. He certainly wouldn't be my mechanic anymore.
I own two, even though a timing chain replacment is beyond my abilities and/or confidence.
Old Sep 8, 2010 | 03:16 PM
Amave's Avatar
or necessary ...unless there was a problem with it..
i have owned several SR20 engines ( timing chain ) and have yet to replace one in 11 years of owning them ...
now timing belts..ugh, let me not get started
Old Sep 8, 2010 | 03:19 PM
Crusher103's Avatar
and i thought i was bad.
Old Sep 8, 2010 | 04:18 PM
SoonerFan's Avatar
Cletus
Old Sep 8, 2010 | 05:38 PM
Someone close this worthless thread please.
Old Sep 8, 2010 | 05:40 PM
Crusher103's Avatar
Originally Posted by SoonerFan
when u think about it, he paid money to have that kind of work done
Old Sep 8, 2010 | 05:44 PM
SoonerFan's Avatar
Cletus
mechanic = some random dude in a shed that charged the lowest amount
Old Sep 8, 2010 | 05:53 PM
CMax03's Avatar
+100%^^^^^^^
Old Sep 9, 2010 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
SR & VQ's =
Need to close it because KA =
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
