Wind noise, ECU reprogram, other TSBs.
Old Dec 15, 2001 | 09:46 PM
jsmith24's Avatar
Hi all,
Well, as part of the ongoing law suit that I have against the local Nissan, I got them to perform a couple of TSBs while they were trying to fix the main problem(s).
First, I had them do the ECU reprogram. It's definitely worth it, just to keep from getting whiplash in first gear.
Second, you simply MUST have the "Rear door wind noise" TSB done - it makes a significant improvement in noise reduction at highway speeds.
That's all for now!
Jack
Old Dec 15, 2001 | 09:51 PM
max'n out's Avatar
Rear door noise fix? And ecu reprogram? more specifics please
Old Dec 16, 2001 | 06:48 AM
mattattax's Avatar
i definitly want to hear more about this
Old Dec 16, 2001 | 07:26 AM
victor's Avatar
here's the wind noise tsb, i found it in the sticky up top.
http://forums.maxima.org/attachment....achmentid=4306
Old Dec 16, 2001 | 02:30 PM
UMD_MaxSE's Avatar
Got Bent?
hmmm... i need to get that wind noise thing fixed....
Old Dec 16, 2001 | 02:41 PM
MichaelAE's Avatar
Wind noise...now I have to go out and see if I notice that. Anything to reduce highway noise would be great.
Old Dec 16, 2001 | 06:37 PM
max'n out's Avatar
I coun't get the wind noise thing to work sombody break it down for me. And what ecu reprogram?
Old Dec 16, 2001 | 07:46 PM
jsmith24's Avatar
Hi guy,
The PDF file is in its 'native form' here.
http://members-http-1.rwc1.sfba.home...ndNoiseTSB.pdf
Basically it says what many of us have known for a while - the rear windows had a 'wind leak' caused by a lack of insulation. The fix is easy, and they should have no problem doing it. Still, print it out and take it with you, just in case they say it doesn't exist.
The ECU reprogram takes care of the "Fuel Cut" issue on manual transmissions. It basically keeps the engine from dropping RPMs smoothly, resulting in jerky operation at low speeds.
Jack
Old Dec 16, 2001 | 08:16 PM
max'n out's Avatar
Originally posted by jsmith24
Hi guy,
Jack
Thanks, thought the ecu thing was new I got happy feet. The rear is nice but it's not that loud at 40 it's above that that sucks. I guess they woun't give it to me.
Old Dec 16, 2001 | 08:18 PM
jsmith24's Avatar
They'd BETTER give it to you, since the first line reads "at 40 mph or MORE."
Jack
Old Dec 16, 2001 | 08:29 PM
max'n out's Avatar
Jack
Opps sorry read it to quick, sorry been a long day im tired.
user 11122324
42
Jul 18, 2022 03:35 PM
bigdogsteve
Jan 31, 2018 04:18 PM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
