Horrible Handling!!
Old Sep 11, 2010 | 05:42 PM
2010MaximaSV's Avatar
Horrible Handling!!
Everytime I get on highway ramp or take a sharp turn at about 25mph or higher the tires start to squeel. The tires have about 70 percent tread and they are Hankook, they cant be the tires? What else could it be? Its an 02 SE auto with 133k
Old Sep 11, 2010 | 05:44 PM
SoonerFan's Avatar
Cletus
i assume stock suspension
any details on the actually handling? (tires making noise really says nothing about the handling)
Old Sep 11, 2010 | 05:52 PM
The KYB struts are fairly new and its like if you go in a car at like 80 on a ramp exit the tires begin to skid thats kinda how it is but at veryyy low speeds.
Old Sep 11, 2010 | 06:04 PM
blasphemy101's Avatar
Noisy tires? Tire pressure? Are you sure your struts are good? Saying you have KYB struts tells us you've had suspension components replaced. Are you lowered?
Old Sep 11, 2010 | 06:08 PM
No its not noisy tires its squeeling tires on corners. The struts are fairly new, a new lower control arm with ball join. The car is stock height. The only option I can think is an alignment but the tires wear off evenly.
Old Sep 11, 2010 | 06:43 PM
Amave's Avatar
when was the last time you had an alignment?
when i 1st bought my car it felt like i was driving on ice...then i replaced all front suspension and steering parts that were worn and did an alignment and now it feels like its on rails when i turn by comparison...
if your suspension setup is in good condition you may just need an alignment
Old Sep 11, 2010 | 06:49 PM
Yes I even had a mechanic check the whole suspension but I forgot to mention this problem.
Old Sep 11, 2010 | 06:50 PM
VQP0WER's Avatar
I think it's just the pavement you're on and nothing wrong with the car.
Old Sep 11, 2010 | 07:01 PM
No its everywhere its def something with the car lol ill try and take a video
Old Sep 11, 2010 | 07:02 PM
Amave's Avatar
dont know if that would be it....he did say it feels like it skids at slow speeds....
an out of alignment will cause that...the feeling that the front is skidding..almost like driving on ice
Old Sep 11, 2010 | 07:03 PM
Mr. Brett's Avatar
When I had new inner tie rods put on my Z, the car was knocked out of alignment (obviously) and had excessive toe-in on one side. The end result was squealing from the passenger's side tire at speeds as low as 15-20 MPH when I turned sharp. And skidding, like you mentioned.
In fact, my Maxima does it right now since I've put my coilovers on, and have yet to get it aligned.
Have you had an alignment done since you put the KYBs on? It's very possible that you knocked something out.
Old Sep 11, 2010 | 07:05 PM
Amave's Avatar
or he just needs an alignment
usually an out of alignment is caused gradually and not instantaneously unless a large curb or pothole is hit
Old Sep 11, 2010 | 07:07 PM
I am not sure as I recently bought the car thats next thing I will do though.
Old Sep 11, 2010 | 07:08 PM
Mr. Brett's Avatar
A car going out of alignment will happen instantly any time you put new suspension parts in because it changes the geometry of your suspension. Even if you swap out OEM for OEM. That's why it's suggested that you get an alignment any time you put any new suspension parts on a car.
Old Sep 11, 2010 | 07:15 PM
Amave's Avatar
sorry i didnt see where he changed his suspension my bad
Old Sep 11, 2010 | 10:25 PM
Mr. Brett's Avatar
No, you're good. I wasn't sure what you were trying to say.
Old Sep 12, 2010 | 01:27 AM
CMax03's Avatar
Install swaybars poly bushing, & strut brace.......
Old Sep 12, 2010 | 08:52 AM
SoonerFan's Avatar
Cletus
he should fix the problem first
Old Sep 12, 2010 | 08:56 AM
CMax03's Avatar
^^^+1 didn't see that part, you're right!
Old Sep 12, 2010 | 12:18 PM
sascuderi's Avatar
Lets see the video!
Old Sep 14, 2010 | 01:48 PM
Haha I forgot to do the video but went for an alignment today and its what it should be at. Much better now
Old Sep 14, 2010 | 02:12 PM
SoonerFan's Avatar
Cletus
cool
Old Sep 14, 2010 | 05:33 PM
Rods03Max619's Avatar
I might say the tires but who know mine on the Max dont do it but right now got a rental and the tires do it all the time like WTF kind of embarassing since its a little Cobalt 4dr like Calm Down Tiger!!
REDinLV
Aug 15, 2024 12:30 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Sep 29, 2015 11:29 PM
zmcneely13
Sep 26, 2015 02:26 PM
