Blue smoke
Old Sep 26, 2010 | 02:29 PM
mickeyiz28's Avatar
Blue smoke
I had a thread a while back on some cel codes and smoke. The car smokes like a forest fire when the rpms goes above 3500. It also has some blue smoke on start up but goes away on idle when it warms up. I haver driven it much but it has to be burning a lot of oil. Do you guys think it's top end or bottom end problems?
Old Sep 26, 2010 | 03:11 PM
nismopc's Avatar
deja vu
Old Sep 26, 2010 | 04:27 PM
CMax03's Avatar
Perform a leakdown test and you'll find your source.....
Old Sep 26, 2010 | 10:35 PM
Scottwax's Avatar
That's Mr. Detail to you
Blue smoke in the engine compartment means a bad oil leak, out of the tailpipe it means bad rings or valves.
Old Sep 26, 2010 | 10:43 PM
I'm guessing your rings are going bad, especially if your cars an '02.
Old Sep 27, 2010 | 11:51 AM
BlackMacks's Avatar
What color is the smoke above 3500 rpm? Black smoke= fuel, blue smoke= oil, white smoke= coolant.
There's not many other fluids that could come out of the exhaust, lol
Blue smoke on start-up is typically indicative of your valve seals being old, dried out and shrunken, allowing the oil sitting on top of the engine after shut-down to leak down the valves into the combustion chamber. Annoying, yes, but cause for an engine rebuild? Nah...
Old Sep 27, 2010 | 01:06 PM
mickeyiz28's Avatar
Yea it's an 02, and it's blue smoke coming out above ~3500rpm
Old Sep 27, 2010 | 03:25 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Stock exhaust? Perhaps those awesome precats have destroyed your cylinder walls...
Old Sep 28, 2010 | 02:41 PM
mickeyiz28's Avatar
Ive been out messing with the car some today. I checked all of the plugs which i just installed about ~200 miles ago and found some strange results. The rear plugs looked brand new while the front 3 did not look so good. The tips on 2 plus where covered in gunk and oil, would score marks on the cylinders walls cause this? I have pics i can load up from my phone if anyone wants to see them
Old Sep 30, 2010 | 07:15 PM
mickeyiz28's Avatar
Anyone got any input on the plugs?
Old Oct 1, 2010 | 06:53 AM
Mr_Van's Avatar
I would say oil leak in those cylinders.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
