Talk to me about low and midrange power...
Old Nov 5, 2010 | 02:12 PM
  #41
Froggmann's Avatar
Here's another thought...
Instead of modifying your suspension, refresh it. Get new tie-rod ends, FSB end-links, FSB frame bushings, ball-joints, and those clever little sub-frame collars. None of that is going to make your tired old struts any better, but the whole thing will still feel more buttoned down.
Great point. No matter how well cared for a car is, after 7-8 years things start to break down. Not to mention fixing all this stuff will make your suspension work much better since the shock from the road will be transmitted directly to your struts instead of your butt. Good call on the subframe collars too. After the installation you will notice a little more engine vibration but your steering will be sharper and the front of your car will be less "mushy", in a good way.
Originally Posted by trooplewis
Since phenolic spacers seem to be a popular mod, I'm curious about one thing.
If you have them and you need to remove your intake manifold again (say, to change your plugs), what do you do, scrape all the old RTV off and apply it again when you reinstall the manifolds?
Hard to believe that such a simple and inexpensive mod would make the kind of difference the dyno charts show. You'd think the mfg's would run A/C coolant through the manifold to keep incoming air chilled for better performance.
Yes they are a re-usable part. But unless you are racing or use Copper plugs like me you shouldn't have to get in there too often.
As for A/C going through the intake manafold? That would cost too much and not result in enough performance compared to the cost.
Sorry for the delayed response, I've been busy most of the day with that 'work' thing.
Rochester, this is my first 5th gen Max so yes, I sort of wanted to whip it into shape quickly so I've been scavenging the forum for the last 3 weeks. Mine was owned by an older couple who had only driven it about 4000 miles per year since 2006, and it was bone stock. No tint, no mods of any kind.
I'm pretty familiar with 4th gen cars, and I loved my Altima right up to the day it was destroyed by a moron driver.
I've done the Progress RSB, and I really like the results.
Not sure what else I would do to the suspension since I'm on the freeway 95% of my driving. Definitely do not want to lower the car, c'mon, I'm 50 years old...
I got most of the acronyms except the 'Stage 1 LTB' huh?
One thing I've been thinking of doing is just replacing the stock muffler with a Flomax 40, just so I could hear the car shift. It is strange having a manual shift and not hearing any exhaust at all.
Yea I know I was in the middle of answering all this then it started to get busy around here too. Anyways to clear up the LTB acronym that stands for "Lower Tie Bar" In essence it further forces your suspension to do the work it's supposed to by (Stage 1) Tieing your lower control arms together or (Stage 2) ting your control arms together and to the body of the car. All this will further firm up rigidity of the car as well as make the front suspension ride much more confidently.
By the way a few links for you
Blehmco
5th Gen Subframe collars
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
