Engine stand - Bolts to transmission area
Old Nov 11, 2010 | 05:47 PM
ampire's Avatar
What are the bolt sizes for a VQ35 where it bolts to the transmission? I think its 12mm with 1.75 pitch, but I want to make sure.
I want to put the motor on my engine stand.
Thanks!
Old Nov 11, 2010 | 08:58 PM
nelledge's Avatar
"I'm just sayin'..."
Thanks!
I just went out to the garage to check for you. I still have the bolts I bought for the engine hoist when I pulled my tranny and changed my oil pan seals. I don't have the packaging with the size on them, however it looks like you're right. 12mm, but I could've sworn the pitch was 1.50. Sorry I couldn't be more help. Hopefully, someone else will weigh in here.
Old Nov 12, 2010 | 04:56 AM
ampire's Avatar
okay, had a hell of a time finding bolts locally, i found 12mm w/ 1.25 pitch and 12mm w/ 1.75 pitch only.
Old Nov 12, 2010 | 05:04 AM
nelledge's Avatar
I got mine at Lowe's. I had to get a little longer than what I wanted, but I just kept the chain close to the block. It was the coarser of the two they had in stock. You're probably right about the 1.75.
Old Nov 12, 2010 | 12:44 PM
ampire's Avatar
yeah its M12x1.75, 90mm long for the top bolts. Bottom bolts look like m10, and are a lot longer, I used standard for these.
Question, when checking compression, do I turn clockwise or counter clockwise?
MAXSE5SPD
Sep 17, 2022 04:00 AM
maxinout93
Oct 27, 2015 01:29 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
