!!! Help !!! I Can't Start My Car !!!!!
Old Dec 18, 2001 | 10:38 AM
AdamK's Avatar
Hey guys I really need some help. I wake up this morning and my steering wheel was locked. I put the key in the ignition and no go. It wouldn't even turn. I tried and tried for at least 30 min and NOTHING. I live in the boondocks so I can't really have my car towed to the dealer so any help appreciated. My friends said I should try switching through the gears and trying but that sounds like BS literallys from Honduh owners. So please help a bro out. BTW I tried 2 different keys to get the same response, NO turning....
Old Dec 18, 2001 | 10:42 AM
emax02's Avatar
Re: !!! Help !!! I Can't Start My Car !!!!!
LOL! You just locked the steering wheel{saftey feature}. While putting the key in the ignitiion turn the wheel to the left or right and you will unlock the wheel.
Old Dec 18, 2001 | 10:43 AM
AdamK's Avatar
Re: Re: !!! Help !!! I Can't Start My Car !!!!!
I'm dumb, however I know that SILLY but that doesn't work Had my mom take a whack at it and nothing
Old Dec 18, 2001 | 10:45 AM
irvine78's Avatar
call for Nissan road side assistance if all fails.
the RSA will tow your car to the nearest Nissan dealership regardless of the distance.
Sprint's Avatar
er.. nevermind
Old Dec 18, 2001 | 10:47 AM
AdamK's Avatar
sprint maybe I'm missing something but isn't it true that you can't start the car without turning the key in the ignition?
btw how does the whole roadside assitance work? timely? cost? i have no extended warentee btw
Sprint's Avatar
check your fuses or something
Old Dec 18, 2001 | 10:49 AM
AdamK's Avatar
hmmmm maybe....do fuses control that? Any idea which one? I have the tech. manual somewhere at home but my new computer is still nto up to date and my old drives are in boxes...it would probably be on the inside under the steering wheel right?
Old Dec 18, 2001 | 11:12 AM
Sprint's Avatar
yes
Old Dec 18, 2001 | 11:28 AM
bcannon's Avatar
Re: Re: Re: !!! Help !!! I Can't Start My Car !!!!!
you have to shake it violently back and forth...
either that or a battery cable is loose...
Old Dec 18, 2001 | 11:29 AM
Sprint's Avatar
Re: Re: Re: Re: !!! Help !!! I Can't Start My Car !!!!!
in this case.. it would be a good idea to see if your dome light turns on.. or your dash lights.. if not.. then you can see what bcannon said as a factor.. if they work.. then rule that out
jjs's Avatar
jjs
Just happended to me two days ago!!!!
Took about 10 minutes fo pulling to each side and trying to get the key to turn AT ALL!!!
It finally just let go and all has been the same since...what I do remember is pulling into the parking space and quickly putting it in neutral and put the parking brake on while pulling the key out pretty quickly as well...maybe the column doesn't like the lock to be 'unkeyed' that fast?!?
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
kirkhilles
Aug 8, 2015 10:53 AM
