how wide can we go?
Old Dec 9, 2010 | 12:27 PM
MOB 02max's Avatar
how wide can we go?
hey guys im looking at some wheels to buy and i was wondering how wide i can fit on my 5.5 gen? i want it to be flush with the fenders and even poking alittle. ?i was thinking 18x10 all around? is that to crazy?? HELP!
thanks
Old Dec 9, 2010 | 12:30 PM
MizzMaxine's Avatar
the rears can work with a roll and maybe even a pull but 10.5 is too large of a width for the fronts
Old Dec 9, 2010 | 12:31 PM
viperboy's Avatar
Originally Posted by MOB 02max
hey guys im looking at some wheels to buy and i was wondering how wide i can fit on my 5.5 gen? i want it to be flush with the fenders and even poking alittle. ?i was thinking 18x10.5 all around? is that to crazy?? HELP!
thanks
Depends on the offset. There are definitely some people on here running some crazy sizes!
Old Dec 9, 2010 | 12:52 PM
MOB 02max's Avatar
i wanted to run these on my max:http://www.xxrwheels.com/xxr_521.shtml
Old Dec 9, 2010 | 01:06 PM
TheArtist's Avatar
Those are nice. A fellow member has those on his 5th gen can't remember what his width was. 18x10 in the rear you will be fine with a roll as for the front that might be a bit too much poke. Guess you could always buy 2 of the 10's and see what they look like up front. You know what offset they are?
Old Dec 9, 2010 | 09:43 PM
MOB 02max's Avatar
i think the offset is +30
Old Dec 9, 2010 | 09:51 PM
10" is definitely too wide for the front.
Old Dec 9, 2010 | 10:58 PM
MOB 02max's Avatar
thats what i was thinking too. what size will be perfect with the front fenders??
Old Dec 10, 2010 | 12:19 AM
whiteSE's Avatar
http://www.nlmotoring.com/XXR-521-Wheels-s/1521.htm
18x10 is only offred with 25 offset.
what i would suggest is get 18x10 rear and 18x8.5 front with +30 offset. add a 5mm spacer later on
Old Dec 10, 2010 | 10:34 AM
LongIslandMax's Avatar
The member you are referring to is MajesticKen. He has xxr 521's 8.5 in the front with 10 in the rear. The only way you can fit a 10 in wide wheel on our cars is if you roll the fenders, and stretch the tires, although even then you might still rub.
*****This is not my car, it belongs to MajesticKen********
Old Dec 11, 2010 | 12:24 PM
Majestic Ken's Avatar
aww my old rims lol. yep they are gone now. i had the car almost touching the lips of the wheels with the coilovers 2 weeks ago. you can run a 9.5 in the front but the xxrs come 8.5. you can run a spacer like i did. if u plan to be droppped low up front then run a 215/35/18 tire. if not then just get a 225/40 series tire. the rear you have to run a 235/35or40/18 tire plus rolled fenders and you can slam it on top of the lip of the wheel. the stretch isnt as bad as people say and it holds up well.
Old Dec 11, 2010 | 01:20 PM
Deckdout2's Avatar
Play with my balls
Or you can get the right offset and not have to stretch the tires too much. 9.5 with a 275 and slammed will fit with rolled fender and right offset.
Old Dec 11, 2010 | 01:44 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Running a 20x8.5 40mm offset 245/35 on the front
Running a 20x10 40mm offset 245/35 in the rear.
Stretched the tires in the rear and rolled the rear fenders. Note: I'm on Tein SS coilovers
If you have an auto the right side (passenger) sits a little further out then the left. Position of the axle.
Old Dec 13, 2010 | 11:19 PM
MOB 02max's Avatar
do you guys think 19x8.5 +32 offset wheels will look good with tein s tech springs. friend of mine has these and said will sell em for cheap http://www.adrwheels.ca/gallery/adrmsportred350z.jpg
(not his car just pic of the wheels)
Old Dec 14, 2010 | 05:04 AM
mine does the same thing and im not auto
Old Dec 14, 2010 | 05:17 AM
j23a45m9's Avatar
I was just thinking about this same question..
I'm looking to go
Front: 19 x 9, 47 mm Offset
Rear: 19 x 10, 30 mm Offset
now i gotta look into what tire set up will make this all work out well. any suggestions?
Old Dec 14, 2010 | 11:01 PM
MOB 02max's Avatar
wow that max is sex!! btw how did you paint the chrome stuff around the windows??
Old Dec 15, 2010 | 04:33 AM
essential1's Avatar
My axles cry for mercy...
10" is definitely to wide for the front.
10" wide has been done before on a 4th gen with no camber and it was slammed. I have pics if you guys want. Clearance is pretty much within millimeters both on the fender side and the strut side though. Not practical for a daily driver.
Originally Posted by Deckdout2
Or you can get the right offset and stretch the tires more.
Fixed
Just bustin your chops.
Old Dec 15, 2010 | 04:13 PM
caseyvr6's Avatar
its all got to do with offset my vette wheels fit perfecly flush with 25mm adapter an 56 offset and thats a 9.5in wheel
Old Dec 17, 2010 | 12:46 PM
a33i30's Avatar
wider in the back=way more understeer btw
02PearlSE
Oct 7, 2015 02:12 AM
DBear
Sep 14, 2015 08:33 PM
jhontelj
Aug 17, 2015 04:07 AM
ericdwong
Feb 22, 2001 10:40 PM
ericdwong
Feb 21, 2001 09:16 AM
