turn signal issue
Old Dec 10, 2010 | 09:12 AM
atomztwins's Avatar
turn signal issue
The headlights blink a bit when I turn on the turn signals and does it again when they go off. The clock and radio lights do it too. The car has a new battery, that was installed just last winter by the previous owner. Is the alternator going? Any help would be appreciated, thanks.
Old Dec 11, 2010 | 04:44 PM
Pete the Sneak's Avatar
If you have an ampmeter start doing some tests. It sounds like it could be a drain issue. Does it do it if you have only the lights on, or only the radio on, not both? Keep us informed.
Old Dec 11, 2010 | 11:16 PM
Max_5gen's Avatar
I think, it's the 'combination switch' - the one you use for turn signal. The power to headlights goes through the same switch, just different contacts. Sounds like those contacts got dirty/loose and don't provide good contact when nearby switch changes its state. I noticed the same on my car, doesn't bother me yet.
Old Dec 23, 2010 | 12:04 PM
atomztwins's Avatar
Thanks guys. Where is the combination switch? I only notice it when the lights are on. It makes the clock, radio and heater lights flash, and now sometimes the radio screen stays bright after the blinker turns off. I have to use the dimmer to get it to go back to normal. Any ideas?
Old Dec 23, 2010 | 12:42 PM
foodmanry's Avatar
Da Roller Coaster!
Inside your turn signal lever. The entire assembly comes off from the steering column with a couple screws or bolts (can't remember which). Take the steering column cover off and you'll see the screws or bolts.
Mine had the same symptoms and I just replaced the entire assembly with a used one I found on here. It has been fine ever since.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
nbstriker10
Sep 4, 2015 04:26 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
