Anyone use an oil drain valve?
Old Dec 30, 2010 | 05:01 AM
  #41
phatboislim's Avatar
this is awesome...i think ima get one. i change my oil frequently too. BTW i hate synthetic, my car burns way more with it
Old Dec 30, 2010 | 06:22 AM
  #42
Stormzusmc's Avatar
Originally Posted by SteveB123
As opposed to the "pipe threaded" valve you suggested above.
Pipe thread is tapered, and seals in the threads.
Straight (non-tapered) thread seals at the gasket.
though its not actually standard npt, not all pipe thread is tapered some are actually straight....
in my case i pulled a couple valves out of my lawson bins and found one that fits and does not leak
Old Jan 1, 2011 | 12:48 AM
  #43
RR5's Avatar
RR5
Happy 2011, I might pick up one. Finally easier oil changes at home!
Old Jan 1, 2011 | 05:12 PM
  #44
trooplewis's Avatar
I did 3 oil changes today in my driveway, and installed the valve on my 5,5 Max.
On a downside,. when I changed the oil in my kids 175,000 mile 1996 Max, the oil came out looking like frothy chocolate milk. See the 4th Gen forum for more on that problem.
Anyway, thought I would post a few photos of how the valve looks installed. It is an easy fix, the same 14mm socket that you use to remove the plug will also install the valve.
Still draining, valve open
Valve closed
The valve protrudes below the oil pan by about 1/2"
Old Jan 1, 2011 | 06:10 PM
  #45
Reece616's Avatar
are those pics of your 5th gen or the sons 4th?
Old Jan 1, 2011 | 06:19 PM
  #46
trooplewis's Avatar
Sorry for the lack of clarification, the valve pic are of my 2002 5.5Gen Maxima SE 6MT
Old Feb 9, 2011 | 08:46 PM
  #47
RR5's Avatar
RR5
Picked up the S type with the smaller nipple and plastic fitting which includes the 3 foot hose. Everyone who changes their own oil should get one, no more draining oil into a catch pan then pouring into a container to take to the recyclers.
Old Feb 10, 2011 | 05:04 AM
  #48
not too bad...where'd you buy from again? SN: kinda worried even though i'm not 'super slammed' i'm pretty low..only thing that would worry me is it getting caught on something on the highway
Old Jun 9, 2011 | 12:16 PM
  #49
CTMaximaSE's Avatar
[quote=trooplewis;7862210]For $23, I've been thinking about buying one since I drive 3000+ miles per month so I do about 14 oil changes a year in my driveway.
Any downside to the valve?
What type of oil do you use? Have thought about using synthetic motor oil, that cut your change time in half.
Old Jun 9, 2011 | 12:40 PM
  #50
TallTom's Avatar
Like raised manhole covers on roads that are under construction.
Old Jun 9, 2011 | 01:43 PM
  #51
RR5's Avatar
RR5
Actually the idea of using one of these drain valves with a hose didn't work in my application.
With the hose, the oil did not flow out freely. After trying and trying, I gave up and went back to draining into the catch pan. However, no more copper crush washers. Just open the valve, drain into pan and done.
Old Jun 9, 2011 | 04:25 PM
  #52
trooplewis's Avatar
Some months later, I'm thinking the valve is somewhat of a waste of money. It does make it easy to get the oil directly into a jug, and you need to have the engine pretty warm ot that takes awhile.
BUT when you remove the oil filter, you still are going to get a big oil spill so you still need a drain pan/container. It just doesn't have as much oil in it as if you drained it all from the start.
Old Jun 9, 2011 | 08:09 PM
  #53
RR5's Avatar
RR5
I agree however the drain valve makes replacing the copper crush washer a thing of the past.
mclasser
22
Nov 12, 2020 01:58 PM
Forge277
Jun 13, 2016 09:26 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
