Stall/no start issue. PLEASE HELP!
Old Dec 29, 2010 | 12:34 PM
Coodawg's Avatar
My car stalled while driving, but the electrical was fine. It started back up after about 20 minutes. It was good for a few days and then decided not to start. It also stalled out while in park after driving it for about 20 mins or so. It never runs rough though, it either runs or it doesn't. This has been off and on like this for a few weeks, but now it won't start at all. I heard the fuel pump energize when it would start, and nothing when it didn't. The pump doesn't energize at all now.
I don't want to just assume it's a bad fuel pump, but do these symptoms sound familiar to anyone?
I've been searching also, but not coming across anything.
Old Dec 29, 2010 | 12:37 PM
ColdRain's Avatar
any lights for battery/ etc? could be starter. what happends when you crank it?
Old Dec 29, 2010 | 12:54 PM
006r's Avatar
Bad connection somewhere??
Old Dec 29, 2010 | 01:00 PM
Coodawg's Avatar
It cranks fine and the battery is strong. The CEL is on, but for an O2 sensor. I do remember some hesitation when punching the gas once on the highway. It still sounds like a failing fuel pump, but don't want to purchase one if it could be something else.
Old Dec 29, 2010 | 01:01 PM
Stormzusmc's Avatar
just saw ur post for the code
... what is the code exactly?
Old Dec 29, 2010 | 01:07 PM
Coodawg's Avatar
I forget the exact code, but it was specifically for an O2 sensor. I was getting a code from the front cat, just to find out I waited to long to replace it and it blew an O2. A Nissan dealer pulled the code and I forget what the number was. How do I check for codes myself? I know it has something to do with the OBDII connector, but I don't know how to do it.
Old Dec 29, 2010 | 01:10 PM
Stormzusmc's Avatar
no offense but if youre not sure how to do it, then i would just take the car into the shop and have them look at it
Old Dec 29, 2010 | 01:13 PM
Coodawg's Avatar
Haha, ok I guess that makes me sound like a mechanical moron! I'm not a master tech, but I do a lot of the work on my cars over the years, but I've never had to pull the codes without a scanner. I just can't get to my buddy's place to use his lol.
Old Dec 29, 2010 | 01:18 PM
Stormzusmc's Avatar
ok so you know you have to have a scanner so youre not completely lost...they really arent that pricey..but if you cant swing 100 bucks or more then just go borrow one from autozone or whatever your nearest store is (call them first)
get the code and come back - its easier to trouble shoot when you have a code or 2...
it could be fuel related, spark related, or ur maf
Old Dec 29, 2010 | 01:58 PM
Coodawg's Avatar
It was the fuel pump relay. I couldn't find the damn thing to save my life! It's in a spot that if you don't know it's there, then you're not finding it.
Old Dec 30, 2010 | 06:25 AM
sontakke's Avatar
Won't you tell us where it is for the next guy who runs in to this problem? Use a cellphone to take a picture if it is difficult to describe in words.
Old Dec 30, 2010 | 08:52 AM
Coodawg's Avatar
You have to remove the driver's kick panel, then remove the 2 screws holding in the ABS control unit (metal box about 6"x4"), then remove the black insulation over a hole in the body frame and there is a gold colored bracket held in by two screws about an inch apart from each other. It's the only one like it, and it holds a blue (fuel pump) and a brown (I believe sunroof) relay. It's almost impossible to see the relays without removing the bracket first. The bracket basically holds the 2 relays inside the fender, which is why it's so hard to see.
Old Dec 30, 2010 | 10:39 AM
ColdRain's Avatar
You're only a CoolDawg, once you upload a picture.
Old Dec 30, 2010 | 10:43 AM
Stormzusmc's Avatar
i guess it pays to read the whole post - silly me...my bad yeah you said at the end of your post there that the fuel pump does not energize now...that shouldve told ya right there (as you figured it out)
Old Dec 30, 2010 | 07:05 PM
Coodawg's Avatar
Turns out that the relay was bad, but the car only started by pure luck after replacing it. The car didn't start again today, and I was able to pull the codes and the camshaft position sensor was also bad. I'll post the pics of the relay soon.
Old Dec 30, 2010 | 07:15 PM
Coodawg's Avatar
view with kick panel removed
ABS unit removed
black insulation removed - gold bracket holds relays in opening
blue is fuel pump relay, brown is sunroof relay
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
Bonka
Sep 14, 2015 11:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
trungg86
Sep 4, 2015 04:58 AM
