idea for more power??
Old Jan 22, 2011 | 05:47 PM
maxima dude's Avatar
this might sound stupid or good...
i was thinking...since the intake manifold has hoses for vaccum..such as the brake booster..front and rear vavle covers etc... and since the maf does not control that air going in ..wut if we routed all the hoses infront of the maf(with oil catch cans for the valve cover hoses so no oil messes up the maf) so it can calculate all the air going into the engine...make a differnce or no?
Old Jan 22, 2011 | 06:12 PM
getflushed's Avatar
that doesn't make sense to me...... the air travelling through any part of the vac. system has been monitored by the MAF, it all comes in through the intake and past the MAF sensor in order to reach those vac lines...... doesnt it? any unmonitored air in the vac lines would create incorrect A/F ratio ( like a vac leak) there should be nowhere else other than the intake where air is entering the intake and dispersed into the vac lines other then through the intake which means, its monitored.
Old Jan 22, 2011 | 06:28 PM
shdwonthsun's Avatar
well, for starters, you'd have a really sh!tty idle and no brakes
Old Jan 22, 2011 | 06:44 PM
bds1304's Avatar
thats to complicated, probably not worth it if there is any gains.
Old Jan 22, 2011 | 06:53 PM
no the lines arent going threw the maf... so it is unmeterd air
how? ull still have vaccum since ur just moving the lines further up the intake..so air will still suck for the brake booster etc.
probably just an idea
Old Jan 22, 2011 | 07:20 PM
not a bad thought, but there's no vacuum before the throttle body
Old Jan 23, 2011 | 11:01 AM
^^ how isnt their? air is still getting sucked in
Old Jan 23, 2011 | 06:52 PM
byrdman164's Avatar
Vacuum comes after the throttle plate. When the throttle plate is closed is when the engine produces the most vacuum. Hence, why diesels don't have vacuum systems, there's usually no throttle plate (so they have vacuum pumps and such). As for unmetered air, sure it's metered. It's not pulling air into the motor from the outside, it's just pulling on a plunger or some other type of vacuum actuated device. The only time it's unmetered is when you have a vacuum leak. Then it becomes unmetered air, when the MAF is unable to see the extra air coming in.
http://en.wikipedia.org/wiki/Engine_vacuum
Old Jan 23, 2011 | 08:29 PM
Chris Gregg's Avatar
Get Off My Lawn
Open up your FSM regarding the recirculation system. Should give you some great insight into the feedback you're getting.
For example, depending upon whether the car is idling or under throttle will determine which direction air is circulated through the the system (through the block).
Actually, in terms of what I THINK you are trying to accomplish.....here's a thought. Just install a GOOD oil catch can on both sides of the system (PCV side and line that runs to the Helmholtz) would illiminate sucking oil into the intake. Blowby gums up the inside of the intake.
I know you're talking about what you believe to be vacuum issues, but the only real issue, speaking regarding a non-boosted engine....is the pulling of oil into the intake. Otherwise, any air you are assuming (the very little that exists) inside the brake booster and other vacuum lines.....is gone as soon as the engine begins to crank.
Old Jan 24, 2011 | 08:14 AM
veery good info you guys are giving... now i see that its useless to try lol
05RLS2
Nov 7, 2016 05:52 PM
Bluenissan
Sep 20, 2015 08:54 PM
rnb754
Sep 14, 2015 11:39 PM
