Smoke @ WOT
Old Jan 27, 2011 | 05:28 PM
mrfxho's Avatar
Smoke @ WOT
So driving on my way home, I made a left turn at a light and I was behind some turd doing about 15-20mph, so I decided to go aorund ( I really had to use the bathroom by the way) so I moved over a lane and floored it and when I looked in my rear view mirror I saw a cloud of smoke !!! So I said to myself that couldnt be me. So when I got to the next red light and once it turned green I floored it agin, but this time from a full stop and same thing, looked in my mirror and there was a cloud of smoke.
I just recently had a fresh oil change done about 700 miles ago so i know its still fresh,
anyone have any idea why this happened or what it might be?
Thks in adavance.
i really hated it bc it made my car look like a rust bucket with allot of smoke coming out the tail pipe and this only happens when I floor it at WOT reaching abt 6500-7000rpms
Old Jan 27, 2011 | 05:33 PM
Mr. Brett's Avatar
Is it black or blue smoke...?
Old Jan 27, 2011 | 05:39 PM
trooplewis's Avatar
Don't go above 5000 rpms, problem solved.
Old Jan 27, 2011 | 06:00 PM
2000_MAXIMA_KING's Avatar
How many miles your car have? I'm asking because your getting bad mpg and smoke sounds like some really clogged up precats to me. Does it smell like firecrackers after you floor it?
Old Jan 27, 2011 | 06:06 PM
Gilly's Avatar
Did you smoke the tires? But seriously, it's possible they over filled your engine with oil.
Old Jan 27, 2011 | 06:16 PM
shdwonthsun's Avatar
this
Old Jan 27, 2011 | 06:19 PM
Clashez's Avatar
daddys here
Old Jan 27, 2011 | 06:24 PM
Mr. Brett's Avatar
Originally Posted by clashez1983
daddys here
Do you ever contribute to any of these threads?
Old Jan 27, 2011 | 07:53 PM
Rods03Max619's Avatar
YEAP CAUSE THATS ME BAD PRE CAT RIGHT NOW....
Old Jan 27, 2011 | 08:43 PM
maxima dude's Avatar
black... blue or white smoke
Old Jan 28, 2011 | 06:29 AM
mrfxho's Avatar
my car as a lil over 145,000 miles and i believe it was white smoke. couldnt really tell becasue it was at night and i saw the smoke through my 10% window tint out of my rear window with car lights in it. but i do believe it was white.
any suggestions???
Old Jan 28, 2011 | 06:34 AM
Bassbreaker's Avatar
possible head gasket leak...supposing it was white.
Old Jan 28, 2011 | 06:43 AM
if its white your burning coolant...headgasket...check your oil and see if its milky white looking... blue is your burning oil and black if i remeber correctly your running rich as ****
Old Jan 28, 2011 | 06:45 AM
phatboislim's Avatar
do it during the day...i doubt its white (signifying HG blown/weak)
Old Jan 28, 2011 | 12:03 PM
if you live where its cold, it was probably just water, have someone give it a few revs and see what you cant smell in the exhaust.
probably water tho to be honest with you
Old Jan 29, 2011 | 07:34 AM
jeff5347's Avatar
mine does the same thing. If i floor it or really get in it and the car has a good load on it such as going uphill it will do it. Pretty sure mine is fuel. My precats are all gutted and have a test pipe in place of the main cat.
Like some other said if it is whitish it is coolant getting into the cylinders and if it is blue is burning oil. That could be anything from getting into the manifold from a bad pcv or in the cylinders from worn rings.
If its black its unburnt fuel as its running rich. As far as i know once it goes into open loop it gives the engine more gas making it running richer than daily driving. If it is black or grey smoke and your running rich and i wouldnt really worry. A friend was behind me and said mine was gray and smelled of fuel.
For some reason the vq35 eats oil from all the 5th gen threads i read as does mine. If it is eating oil honestly the only fix is either new rings or a better oil catch can design which i dont see happening soon. Just gotta live with it .
Finkle
Sep 27, 2015 09:53 PM
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 10, 2015 09:35 PM
Balkins
Aug 12, 2015 06:39 AM
