removing upper after spacer install
Aside from my question, have you tried a rubber cooking spatula?
No, seriously. As goofy as that sounds. The rubber will be less likely to damage the mating surfaces.
Another alternative, I suppose, is a plastic putty knife. Or a decal squeegee.
Nothing to pry against bro. tried my pickle fork for a little extra oomph, no dice.
Of course i have spacers brett
throwing that **** as far away as i can from my damn car lol. honestly i paid forty for the stock replacement, you give me forty and its yours. YOU WILL NEED A BOP LOL, Cause mine is transferred over
Yeah, its kicking my ***, permatex for the win
Did get to swap in the powdercoated heater core lines, but this is still sitting there laughing at me...
Not gonna work in this instance bro. the elbow is removed. the bop is removed, the entire upper wont seperate from the lower and spacer. No way to get in between with a screwdriver much less a spatula lol
yeah emailed him.
Got it finally. Took the torch to it and just stayed away from the spacers for about five minutes, then put the fork over the screw holes and hit it with a baby sledge. finally rocked loose on one side then was able to pry it.
So without direct heat you wont tear the spacers up if you use a torch. thanks yall
This is good info. I've been contemplating removing my ssim too. I'm curious to your impressions after going back to stock (as a fellow AT).
BTW did you get rid of the middle piece on the spacer that connects the elbow to the UIM? I did and I'm wondering how that'd be on the stock one too..
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
jds22
Sep 4, 2015 01:52 PM
