Back on the road again!
Old Feb 9, 2011 | 07:04 AM
HOMERUN4THGLE's Avatar
Well just got my car back on the road after a 4 month break. Slapped a curve and destroyed a rim, lower control arm, tie rod, bent strut, broke srtut from spindle, abs sensor, brake line and a axle. Roughly 1800$ bones of repairs!
Well i have this growl coming from my engine and it is heard around 2 or 3rd gear. It is loud when the car is driving and warming up but as I drive more and the engine warms up it is not as vocal as it is when it is cold. Any ideas? I am going to change my oil again but I am going with a Mobil1 filter and Royal Purple oil and see if that calms my babies growl.
Any suggestions I would appreciate as well as any reference to a "GOOD" Maxima mechanic in the Raleigh,North Carolina area.
Old Feb 9, 2011 | 08:45 AM
nismopc's Avatar
Check motor mounts. Can cause engine noise.
Old Feb 9, 2011 | 09:06 AM
rosader's Avatar
What he said^ If all that was damaged you may have hit hard enough to damage a motor mount too.
Old Feb 9, 2011 | 05:45 PM
BoDenKai's Avatar
mine does a wierd growl when i hit a bump in the city. I was thinkin that it was the axles and tranny being stressed out too much from a bump with my dead shocks and fail dead bushings
Old Feb 10, 2011 | 10:01 AM
Motor mount
Thanks for the tips. I do not think it is internal I switched over to RP with a Mobil1 filter so she is smooth as butter. But I still get the rumble around second or third and it is coming from the passenger side. So I am going to have the Motor mounts checked and exhaust. When I get into her she moves out but that rumble comes in and out. I will post after I have the mounts checked.
Old Feb 10, 2011 | 10:41 AM
Scottwax's Avatar
That's Mr. Detail to you
I could not get over how much quieter my engine was after replacing the passenger side engine mount. It was literally a night and day difference.
Old Feb 10, 2011 | 10:53 AM
Boost_boy's Avatar
More than likely it's your flex pipe that's starting to fail. As the engine moves back and forth, it makes more and less noise. Should be around $100 to have a repaired by an exhaust shop.
Dee
Old Feb 10, 2011 | 08:29 PM
Its officially the cat
Went to a garage and the mechanic took it for a test drive an placed it on a rack. He took a hammer and tapped my cat and dust popped out.
So I am going to get a new cat and o2 sensor and go from there!
Old Feb 11, 2011 | 08:48 AM
rosader's Avatar
Was it cat or precat? If precat you might want to look into upgrading to headers. Oh and a bad cat would make a rattle not a growl are you sure that's what was causing the noise?
Old Feb 11, 2011 | 09:46 AM
water Bottle
After talking with someone they seem to agree it is not the cat but the resonator after the cat. I am not to sure because the bad part is shaped like a water bottle. Is that the cat or resonator?
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 2, 2015 07:43 AM
